How do I get the carbs and airbox together?
- jrjstuff
23 Jan 2008 18:52
Well its been a few years and a few bikes since I have been here, but I am back with a new project. I just got a 6/82 kz750H. It came pretty much complete but not running. After rebuilding the carbs I went a bought an airbox for it. Now my question.. how the heck do you get the carbs in the intakes and the airbox boots on the carbs at one time. I am not some rookie at mcycle mechanics but after an hour+ I figured that someone may know a trick or two. Anyone with a trick or idea to offer would be greatly appreciated. The bike runs now but it has been my experience that it will do so better with the airbox attached.
Jeff
83 KZ750 ltd
83 KZ750 ltd
- ran429
- Master of FREE rides!
Re: How do I get the carbs and airbox together?
23 Jan 2008 19:14
the air boots will slide back into the iar box, you will mount the carbs into the intakes, then one by one working from the middle out push the boots forward and then using a dull flathead driver or rounded off ice pick like tool (as a shoe horn for say) pry the boots back over the carburetors.
P-I-T-A for sure, but you will manage.
- Locozuna
23 Jan 2008 19:37
If the boots are in good shape and not too hard fold them over on themselves. This will give you an additional inch+. Then install the rack to the head. Unfold the boots onto the carbs. It is the easiest way I know of if you have soft boots. I will always buy new boots if they are not soft enough. I have heard if you heat the boots they get softer but my experience is different.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- minutiesabotage
23 Jan 2008 19:54
I sometimes spray the boots with silicone, makes them much easier to work with. Just make sure that it doesn't get into the carbs/engine.
- jrjstuff
24 Jan 2008 06:45
I actually got the boots onto the carbs by doing just that, pushing the boot into the airbox. My problem is I cant seem to move the boot enough to get them to actually seat in the box again.
Jeff
83 KZ750 ltd
83 KZ750 ltd
- Locozuna
24 Jan 2008 08:37
Did you see this old thread?
tinyurl.com/2edfsb
I do the same thing that Ambergrismooon does. Makes it easy.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- Bluemeanie
24 Jan 2008 11:01
I realize money is tight for most of us but after fighting my 28 year old hard as a rock shrunken boots (heating (melted!)lubing, etc) I decided F**k it and spent the money on nice new soft ones. Now I just insert inside air box and work onto carbs. Pretty easy now, especially on a warm day! Trust me, worth every penny!!
- Spot
24 Jan 2008 18:16
Definitely buy new ones if they still make them!!! see thread "Need Expertise on Rubber Softeners". Until I bought new inlet ducts, I was seriously considering pods (which would require bigger jets, I believe).
Good judgment comes from experience, which usually comes from bad judgment. - Will Rogers
- jrjstuff
25 Jan 2008 09:22
Well I thank you all for the good advice. Now can anyone lead me in the direction of new intake boots and does anyone have a ball park figure on cost?
Jeff
83 KZ750 ltd
83 KZ750 ltd
- WABBMW
- Let The Good Times Roll !
25 Jan 2008 10:44
New boots are the best, but I have had success by using a hair dryer and heating each boot, one at a time for several minutes, then inserting it through the air box and toward the carb. Then use a large flat screwdriver to carefully push on the edge of the boot to slip it onto the carb, with the help of your other hand on the opposite side. Sometimes you have to use a smaller screwdriver to insert inside the boot to help it get over the outer edge of the carb. Keep applying heat as you work. This is not an easy job, hence the new boots are sweet.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- ThatGPzGuy
25 Jan 2008 17:21
Easy on the silicone spray. If you get it on paint it will never come off and will screw up any re-paint you do. No first-hand experience with this but heard it from a painter-friend. The stuff is banned from his garage.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
