Wrong jets cause?????
- ran429
- Master of FREE rides!
22 Jan 2008 20:23 #190574
by ran429
Wrong jets cause????? was created by ran429
Would the wrong jets on a bike with pods & kerker make a sputter in the carbs too?
or do i need to dig deeper in the timing again?
my intakes are in great shape and seal sweet. just wondering if that carb popping on #4 will stop?
- Bluemeanie
- Thank you received: 14
22 Jan 2008 20:30 #190582
by Bluemeanie
Replied by Bluemeanie on topic Wrong jets cause?????
Is it popping or are you hearing the individual pulses?
- ran429
22 Jan 2008 20:40 #190587
by ran429
Replied by ran429 on topic Wrong jets cause?????
no, its popping back through the carb here and there, you can even see it bulge out the pod filter.
- Bluemeanie
22 Jan 2008 20:48 #190591
by Bluemeanie
Then I would want to think timing. But only out of #4? Would think timing would effect all carbs. Strange... could be fuel, tried playing with air/pilot screws? How's sync?
- ran429
23 Jan 2008 05:40 #190620
by ran429
- BSKZ650
23 Jan 2008 11:40 #190664
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Wrong jets cause?????
ran429 wrote:
I see the problem, that is a guy bike not a she bike:P
if its only on #4 have you checked the valves to see if the intake might be tight
heres how she sits now
- ran429
23 Jan 2008 15:08 #190697
by ran429
no, as it sits right now it has "NO BALLS"
Now this weekend, i will install some on her making it back into a Him.
- KZ_Rage
- Kentucky Bourbon Barrel Ale
- Thank you received: 19
23 Jan 2008 15:19 #190698
by KZ_Rage
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
Replied by KZ_Rage on topic Wrong jets cause?????
You could still have an air leak on #4 carb, just hard to find. You might want to check the diaphragm on #4 carb and the valve clearance on #4 at the same time. Be careful so as not to tear the diaphragm when removing the top if it hasn't been off in a while as they stick and tear easy.
Those CV carbs and pods are hard to balance and jet properly by design of the carb. If you can get a set of VM's you'd be better off in the long run. That all said if the bike was running good and just started this issue then try to find the air leak first then check the rest.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
