parts question
- lucas808
16 Jan 2008 17:53 #189637
by lucas808
parts question was created by lucas808
does anyone know where i can find a relacment part like this? mine is leakin like crazy.
- lucas808
16 Jan 2008 17:57 #189638
by lucas808
Replied by lucas808 on topic parts question
sorry the pic not loadin,any way the part in question it the "T" where the fuel goes into the carbs from the tank. I have checked with all the local bike shops and keep getting the same answer, "discontinued", i also called Z1 and they had no solutions either. any ideas on how to fix or where to get it would be great.
thanks
thanks
- The Milkman
- Thank you received: 194
16 Jan 2008 18:02 #189640
by The Milkman
Replied by The Milkman on topic parts question
I sent you a PM
- The Milkman
16 Jan 2008 18:19 #189642
by The Milkman
Ok, from your PM I take it that they leak where they enter into the carbs. Several people on here have said that they wrap the ends that go into the carbs with teflon tape for the plumbing area of their local hardware store. The fuel tube of my petcock was loose and weeped a little, I used the teflon on it and it's okey dokey now.
You should be able to find o-rings that fit in the same area of a hardware store or an auto supply store.
Good luck.
Ride safe
Good luck.
Ride safe
- BSKZ650
- Thank you received: 14
17 Jan 2008 04:53 #189683
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic parts question
go to a good parts store, napa types, they have o ring assortments they can get one that is real close to the right size.
I have heard the teflon tape deal, but I dont trust it, teflon tape is used as a lube to keep the threads from gualding until they are tight enough to seal and fuel at some point is going to get by the tape
- bubba_d
17 Jan 2008 07:06 #189696
by bubba_d
1977 kz1000.
Replied by bubba_d on topic parts question
well regardless of what you need i wouldnt go to bikebandit.com. i was screwed by them last week. their solution was to give me free shipping next time, however there will not be a next time for me. lust thought i would advise others
1977 kz1000.
- lucas808
17 Jan 2008 13:45 #189781
by lucas808
yes they leak where they go into the carbs. they have a rubber piece on them that has two o rings that are made in them, but you can't just put o rings on them according to the local bike shop that deals with older bikes like these. try the pic again,
Post edited by: lucas808, at: 2008/01/17 16:47
hey it worked, lol, but this is the part i was tryin to find, if i could just get the rubber part it would be great but at this point ill try anything, i have replaced everthing else in and on the carbs, had nothin but carb trouble out of this bike,
Post edited by: lucas808, at: 2008/01/17 16:49
