jetting help
- kz750ohio
08 Jan 2008 21:32 #188353
by kz750ohio
1982 kawasaki kz750 with mikuni carbs bs34, stock everything else.
jetting help was created by kz750ohio
Hello everyone. I just bought a 1981 KZ750-4. It needs some work but I have plenty of time up here to give her.
I was needing to find out what jets are needed for the carbs. The owner I bought the bike from gave me a set of Mikuni BS34's from a CSR (opps) I mean GPZ. He said that I might need to rejet them to work on this bike. I was thinking about going to pods instead of the factory air box but I have read on this site the factory box seems to allow it to run smoother or at least that is my understanding. Could someone help me with this and where could I buy the jets. I will post some picks once I get into her a little bit more. I picked up a repair manual today and I downloaded the Kawasaki one off the net. Now the fun begins.
Cheers,
Max
1981 KZ 750-4
14,000 on the speedo
Stock everything at least as far as I know.:
Post edited by: kz750ohio, at: 2008/01/09 11:39
Cheers,
Max
1981 KZ 750-4
- wiredgeorge
09 Jan 2008 06:36 #188391
by wiredgeorge
Replied by wiredgeorge on topic jetting help
I would give the carbs a try with stock jetting if you use the stock airbox.
- kz750ohio
09 Jan 2008 08:41 #188407
by kz750ohio
Replied by kz750ohio on topic jetting help
thanks. I am going to take them apart tonight and go through them and see how dirty they are and if they need to be rebuild. At the least I will clean them.
