Another Starting Problem
- wiredgeorge
10 Jan 2008 08:39 #188550
by wiredgeorge
Replied by wiredgeorge on topic Another Starting Problem
I have been burned so many times when buying used bike stuff that I have learned to be cautious and take claims with a grain of salt. When I buy any vintage bike, I do some things to save time and money:
1. check compression, check cam chain timing, adjust valves, adjust cam chain
2. verify ignition timing and verify ignition wiring is correct
3. replace carb holders before attempting any carb work
Tune up steps for any bike are the same: valves/timing chain, ignition and then carbs. I could probably take a few minutes to tell you about some of the issues I have had by ignoring doing things in order, but it depresses me to think about all the dumb things I have done. Experience has taught me to verify everything on a bike that is new to me.
- kzwolfsr
- Thank you received: 16
11 Jan 2008 18:30 #188784
by kzwolfsr
Original man of the Caribbean
Replied by kzwolfsr on topic Another Starting Problem
Also try changing your spark plug cables. same thing happened on my jeep. drove to the store, turn it off and when I came back, no start!
