Idle issues
- EasyRider1
04 Jan 2008 20:52 #187712
by EasyRider1
1978 KZ650C
Idle issues was created by EasyRider1
I don't know if this should go in the carb section or engine section but here's the deal:
My bike will idle when warmed up and runs fine but when I rev it up and come to a stop sign/light, the bike rpms will drop and the engine will shut off(about half of the time).
Let me also mention that I have to leave the choke on just a hair for the bike to run/idle/stay running. I'm guessing that when I open up the trottle significantly, the choke is being pulled open all the way and therefore the bike shuts off.
I thought this was due to the fact that I didn't have an air filter (to give more drag and eliminate the need for the slight use of the choke) but I installed one and still the same problem. Any thoughts?
Post edited by: EasyRider1, at: 2008/01/04 23:53
1978 KZ650C
- themachine
- Thank you received: 4
04 Jan 2008 22:22 #187719
by themachine
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
Replied by themachine on topic Idle issues
leaky intake boots or a vaccume leak somewhere, the carb holders/boots/rubber intake runnder dry out and get cracked after a while then they suck in air.
z1enterprises carries them for 50$ +s for a whole set.
Post edited by: themachine, at: 2008/01/05 01:23
- EasyRider1
05 Jan 2008 06:42 #187738
by EasyRider1
1978 KZ650C
Replied by EasyRider1 on topic Idle issues
Well, I recently ordered some new carb holder boots so I maybe that will help out. Would it matter if the boots coming from the airbox were a little leaky?
1978 KZ650C
- KZQ
- Administrator
- Thank you received: 1414
05 Jan 2008 07:52 #187745
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Replied by KZQ on topic Idle issues
"Would it matter if the boots coming from the airbox were a little leaky?"
Only in that the air that leaked into the intake at the airbox side boots would be unfiltered.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
