noticed something
  • quader98
  • quader98's Avatar Topic Author
noticed something
27 Dec 2007 14:36
#186594
i was doing a compression test today,got to almost 150 to all cylinders by the way,threw in new plugs and ran it for a couple of minutes. pulled the plugs and noticed that 1 and 4 had carbon fouling while 2 and 3 looked good.looked around the carbs a little and saw that where the vacumm plug goes on 1 and 4 had a tube that interconnected the two carbs...is this right? my E2 isnt set up that way
Post edited by: quader98, at: 2007/12/27 17:38
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: noticed something
27 Dec 2007 20:14
#186649
Do you have a vacuum controlled petcock? Probably been removed. That would account for one vacuum tap. How about the air injection system? Does or did the bike have one? If so that would account for the second tap. If both have been removed a common treatment is to join the two together.
If 1 & 4 or 2 & 3 are exhibiting similar symptoms I'd look toward the coils as that's how they're paired.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • quader98
28 Dec 2007 10:13
#186726
yea it still has the vacuum controlled petcock coming off of carb #2.im assuming that the air injection system has all been removed since it has pods and nothing else.ive been reading all morning about testing coils,my brain is mush.ill give em a test and see what i get...thanks
82 GPZ 750 R1
