What's wrong with my bike?
- EasyRider1
21 Dec 2007 08:37 #185938
by EasyRider1
1978 KZ650C
What's wrong with my bike? was created by EasyRider1
My bike was running fine until yesterday. I took a carb boot off and was going to replace the airbox with pods but decided not to. I put everything back to normal. Now when I try to start my bike it won't idle right and it sounds like the carbs are spitting(air coming back from the engine and out through the carb boots. Also, a little bit of liquid (water I think) is dripping out of the exhaust (I think) connections. What is wrong? Did water get into my engine or what?
1978 KZ650C
- EasyRider1
21 Dec 2007 10:02 #185944
by EasyRider1
1978 KZ650C
Replied by EasyRider1 on topic What's wrong with my bike?
Duh! I figured it out. It was the upper hose on my petcock that slipped off when I removed the boot. I suppose that is some sort of fuel vacume?
1978 KZ650C
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
21 Dec 2007 10:33 #185946
by Skyman
West Linn, OR
Replied by Skyman on topic What's wrong with my bike?
EasyRider1 wrote:
Yes, it is likely the vacuum hose that actuates the petcock valve. No vacuum, no fuel flow (unless you set your petcock to the PRI position).
West Linn, OR
- Skyman
21 Dec 2007 10:35 #185947
by Skyman
West Linn, OR
Suggest you put your bike type and location in your signature, so we always know what kind of bike(s) you have when you post questions.
West Linn, OR
- EasyRider1
21 Dec 2007 11:09 #185951
by EasyRider1
1978 KZ650C
"No vacuum, no fuel flow (unless you set your petcock to the PRI position)."
I guess thats why it would run ok for a few moments when I primed it first.
Post edited by: EasyRider1, at: 2007/12/21 14:09
1978 KZ650C
- BSKZ650
- Thank you received: 14
21 Dec 2007 11:42 #185954
by BSKZ650
Post edited by: BSKZ650, at: 2007/12/21 14:43
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic What's wrong with my bike?
