Pod Filter Help
- EasyRider1
20 Dec 2007 17:06 #185876
by EasyRider1
1978 KZ650C
Pod Filter Help was created by EasyRider1
I have another thread going regarding air filters and since I'm considering losing the air box all toghter and putting in some pod filters, I thought I'd post my question:
What am I supposed to do with the breather tube if I get rid of the airbox?
1978 KZ650C
- quader98
- Thank you received: 1
20 Dec 2007 17:12 #185877
by quader98
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
Replied by quader98 on topic Pod Filter Help
you have to get filter type thingys for that as well
82 GPZ 750 R1
- Aric
20 Dec 2007 19:51 #185895
by Aric
Replied by Aric on topic Pod Filter Help
If you are referring to the crankcase breather at the back of engine case near or above the trany;
Option 1. - I just went to pods myself and simply ran a new hose and looped it over to sit directly above my chain. That way if any oil should "burp" out it will (hopefully) act as an automatic oiler for the chain.
Option 2. - Go to JC Whitney or Ebay and run a search for "Crankcase Breather Filter". I also bought one of those but I hooked it up to my emmissions control valve so as not to suck "raw" air into the valve cover or vacuum valve. Their main function is for the crankcase breather. They are nicely chromed. Will try to add the pic.
Post edited by: Aric, at: 2007/12/20 22:52
Post edited by: Aric, at: 2007/12/20 22:54
- Aric
20 Dec 2007 19:57 #185896
by Aric
- quader98
21 Dec 2007 01:52 #185908
by quader98
82 GPZ 750 R1
IMO,i wouldent leave it open like that ,anything could get in and contaminate the oil.for the little investment of a breather it would give me great piece of mind
82 GPZ 750 R1
- wiredgeorge
21 Dec 2007 06:08 #185924
by wiredgeorge
Replied by wiredgeorge on topic Pod Filter Help
I like to just put a hose on the crank breather and run the hose over the swingarm. In the event you have blow-by, the oil will QUICKLY foul the little crank breather filters... this means that the crankcase will quit breathing and you can damage the engine. I am not sure what would get into a hose and back into the crankcase except perhaps mud dabbers or insects as the pressure is outwards when the bike is operating.
