- Thank you received: 12
Ever used an air pump on the gas tank ?
- JimatMilkyWay
My fire breathin' monster ran out of gas yesterday. I was out just putzing around real easy, well, sort of. When it, sort of "ran out of gas" I stopped, opened the cap and "sealed my mouth" on the fill hole such that I could pressurize it and help the fuel to fill the bowls. I wonder, if I connect a air compressor to it and put five psi (or so) pressure in/on my fuel tank all the time if it would cause a problem, like fuel leak or cracked paint job. The problem with the fuel pump idea I discussed in my previous thread, kzrider.com/component/option,com_joomlab...w/id,183021/catid,3/ is that I don't want to lose the oem vacuum petcock.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
If very low on gas, you can sometimes "squeeze" the last few drops of petrol out by leaning the bike to the left (while stopped :whistle:) so that the gas from the right side can flow over to the petcock. Be careful not to dump your bike while trying this. :pinch:
West Linn, OR
- 79MKII
- Love Them Kaws!
- Thank you received: 43
...if I connect a air compressor to it and put five psi (or so) pressure in/on my fuel tank all the time ...
You're gonna need one really long air hose!
I think the vent would do it's job and vent the pressure.
The Kaw List:
- JimatMilkyWay
I already thought about that. I was going to make a special adapter and plumb my gas tank to my front tire, but then I realized the _back_ tire holds more air.JimatMilkyWay wrote:
Easy enough to defeat. I really would like you guys to give this some thought and tell me what would be the best and the cleanest way to plump it in so that I can reverse it when I am done.I think the vent would do it's job and vent the pressure.
Post edited by: JimatMilkyWay, at: 2007/12/11 13:56
- School Teacher
just an idea:)
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- JimatMilkyWay
Perfect!! Thanks teach!put an air horn on your bike and use the pump for that?
just an idea:)
I'm just glad I thought of that!:laugh: :laugh:
I'm thinking to plumb in a low pressure gauge so I can report on exactly what-is-what, so to speak.
As stated previously I was pressurizing the tank out on the road so I could make it back home. Well, I did so while idling and the engine actually changed rpm when I was squeezing on the air. I was not interested in any _careful_ observations at the time. There will be plenty of opportunity for that a little later. I just thought it was interesting.
- JimatMilkyWay
Thanks Skyman; I had over half a tank; WELL over half, but they will still run out if the fuel is not making it into the float bowls.So, I'm not sure if I follow you. Are saying that you WERE low on gas? .... :pinch:
- JimatMilkyWay
Thanks dudeI am not sure the needles and seats could take that kind of pressure and still seal when needed, the are meat to work on a gravity feed wich is alomst no pressure
I understand the original engineering calls for gravity feed, but you know how some people just can _NOT_ resist re-engineering EVERYTHING.
I feel that a major improvement could be realized if done correctly and I would still have use of good paper element filters instead of sintered, scentered, centered well what ever, brass bb screens. Or possibly I just don't trust the bb's because I have never investigated them. I have, however observed for thirty years how a good fuel filter can keep crapola out of the engine and carbs.
Jim@MilkyWay
- School Teacher
1980 kz1000G1
- JimatMilkyWay
Yes, tucked in under the frame and back of the carbs are two bulky in-line paper units. One for each supply line from petcock. Then, in each carb supply line, viz 4 each, are those little disposable, sintered brass jobbies. They are all brand new with less than 300 miles ride time and a very clean and freshly coated(?),,, remember I came up with this idea myself, fuel tank.are you running inline filters?
- loudhvx
- Thank you received: 1616
Ha ha, I've had to do this a couple times over the summer myself until I replaced the filters.Well youse guys
My friend had to do it to his KZ400 when his filter suffered the same problems as mine.
... and yes, I've heard all of the "blowing the bike" jokes so let it go... :laugh:
But if you have the brass filters, then I have to agree with RetroRiceRocketRider. It's probably the tank coating you did. It is somehow dissolving and plugging the filters. You may have to bite the bullet and get a new tank (or petcock if it's the petcock screen that's getting sealed).
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
