FUEL LEAK
- Godzpeed
1980 KZ750H1
Thanks guys!
- mariozappa
- Thank you received: 8
1977 KZ650C1
and the KZ650/KZ750 Conversion
- Bluemeanie
- Thank you received: 14
- Godzpeed
- Paladin
I found if you route two tubes out one side and two out the other, you can tell exactly what carb is over flowing. Maybe there is some grit in the float valve that needs to be cleaned out. It also does this when i leave my fuel valve on. Hope this helps.
-Bobby
- Bluemeanie
- JimatMilkyWay
- Thank you received: 12
Only sissy's use a flashlight.You almost have to catch it in the act.... I take a flash light which makes it easier to see....
You can see just fine if you get in there close enough, using a cigarette lighter.:laugh: :laugh:
Jim@MilkyWay
- Little B
- Thank you received: 3
:laugh: :laugh:Only sissy's use a flashlight.
1981 KZ750-H2 LTD
- JimatMilkyWay
Little B!!:laugh: :laugh:
