- Thank you received: 3
Bigger Bore--Changes to jetting?
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
30 Jul 2008 21:40 #229284
by Skyman
West Linn, OR
Replied by Skyman on topic Bigger Bore--Changes to jetting?
Skyman wrote:
Anyone?????
Still hoping to hear some advice on my main jets. The engine bogs at WOT. Should I go with larger or smaller mains?
Thanks.
Anyone?????
West Linn, OR
- mark1122
- Keep twisting it
- Thank you received: 109
01 Aug 2008 10:42 #229559
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Bigger Bore--Changes to jetting?
Leave the needles alone for now. no need to change the only part that is working right at this point.
As for the pilots, do u need a lot of choke to start or half choke? This may give u an idea of whether it is rich or lean. u can also try a bit of choke while riding to see if it likes more fuel in the trouble zone.
u should put tape on the grip and mark off 1/8th , 1/4, 3/4, and full throttle positions. Remember that the pilot serves 0 to 1/4 throttle. Needle = 1/4 to 3/4, mains= 3/4 to full. There is defiantly an overlap from circuit to circuit but stick the formula for now. As u in crease the mains it richens the top of the mid a bit.
After riding the bike at cruise for a few miles at 1/8th throttle, with 1 new spark plug, do a plug chop. This will tell u for sure which way to go on the jetting.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Skyman
01 Aug 2008 14:34 #229586
by Skyman
West Linn, OR
Thanks for responding, Mark.
To answer your question about starting with choke, it usually fires right up with 1/2 choke. And I generally need to take the choke off within 30 seconds or it starts to run rough.
So, does that mean I may be on the rich side?
West Linn, OR
- mark1122
- Keep twisting it
02 Aug 2008 09:12 #229677
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Skyman wrote:
Possibly rich , but no obvious answer there with 1/2 choke.
Best do to the plug chop as i described above. if u have any questions feel free to pm me and we can chat or phone.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Skyman
02 Aug 2008 15:44 #229739
by Skyman
West Linn, OR
Thanks again, Mark.
Right now, I'm repainting my tank, so when I'm done with that, I'll work on doing the plug chop test. I'll let you knoe what I come up with.
West Linn, OR
