How to Identify a Carb
  • KZer
  • KZer's Avatar Topic Author
17 Jan 2006 17:54
#18329
Hey Carb Guru's!
Any idea on how I identify what model of carb I would have on my '77 KZ650B? They appear to be stock, cuz when I disassembled them (just removed the bowls), nothing looked tampered with (except the float level). I installed pods and was told that I would need to re-jet them. Help?
  • reborn650
  • reborn650's Avatar
Re: How to Identify a Carb
17 Jan 2006 18:06
#18331
They look like Mikuni 24's 2 me.
Cheers - Colin Firth '77Kz650 Custom
-1998 Jeep TJ Wrangler 4.0 litre for the kids
-1975 Zamboni - The real Italian sportscar fully restored and functioning every winter at our local outdoor playground rink.
Mine is an ecclectic collection of motorized toys - LOL
I have a newspaper route and a web site where you can plan your own funeral life celebration www.mysendoff.com ....and go out with your own style.
  • reborn650
17 Jan 2006 18:06
#18332
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
17 Jan 2006 22:06
#18386
They are 24's...off of a 650,I believe.The lines on the bodies are a dead give away.B)
1977 KZ1000 A-1
  • KZer
18 Jan 2006 05:07
#18410
IF they have standard jets, what would I need to tell my local dealer what I need to replace them with so I can get a proper mixture? I just spent a pile of money and time rebuilding the engine's top end and I REALLY don't want to go through that again because of a lean fuel mixture.:S
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
18 Jan 2006 06:51
#18422
Welcome to KZR.
Here's a Jet Link from the Archives. Do a search in the Archives above for more info.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • wiredgeorge
  • wiredgeorge's Avatar
18 Jan 2006 07:45
#18431
Main jet sizes vary from #90 to #102.5, the jet needles and needle jets are different and other internal components from one type VM24 to the other.
What size jets are in those carburetors now?
  • KZer
18 Jan 2006 17:22
#18555
Thank you VERY much for the great response guys:) One more question,how I know which size jets I have?
  • 77KZ650
  • 77KZ650's Avatar
18 Jan 2006 19:38
#18582
The size of the jet should be stamped on it.
07 MDP Rookie of the Year
  • wiredgeorge
19 Jan 2006 07:21
#18640
The main jets are screwed onto the ends of the main jet holder tubes. Hold the tube (which is screws in) with an 8mm wrench and use a large flat blade screwdriver to remove a main jet. Use a small flat blade screwdriver to remove a pilot jet. Some pilot jets have an additional #50 barrel type jet screwed in over the top. If you have these, remove the barrel jet using a flat blade screwdriver then remove a pilot jet beneath. If you can't read the small numbers, it is often helpful to use some steel wool and polish off the surface as they do tend to get cruddy. A number will be stamped on the pilot jet of either 15 or 17.5 and a number will be stamped on the main jet of either 90, 92.5, 95, 97.5, 102.5, etc.
  • KZer
26 Jan 2006 11:24
#19962
I cheated and wrapped the pods with an open cell foam and it balanced the air low and keeps the snow and junk from getting in the engine. Maybe will rejet in the spring...In case you're wondering what the heck is this guy doing driving his bike in the winter?! The engine isn't in a bike (per say)...It WAS a golf cart when I started a year and a half ago...
Post edited by: kzer, at: 2006/01/26 14:25
Post edited by: kzer, at: 2006/01/26 14:26
  • KZer
26 Jan 2006 11:34
#19964
Here's a pic of the engine before I finished the rebuild.
