carb gasket material
  • fishybass
  • fishybass's Avatar Topic Author
25 Nov 2007 20:22
#182674
Hi all,
I am in the process of cleaning my carbs. They were stripped down, made shiny and now I'm reassembling them. Not wanting to dump $100 on a set of carb rebuild kits, I am taking the do-it yourselfer way out and making new gaskets.
Under the carb covers I used treated paper.
But the gaskets for my float bowls were so fubar I cannot tell... were they paper, rubber, or something else all together? It looks like it could be paper but it surprises me that paper gaskets held up so well for 25000 miles.
If they weren't paper... would paper gaskets work for float bowls?
  • oldkaws4ever
  • oldkaws4ever's Avatar
  • Have no regrets...... You only live once.
Re: carb gasket material
25 Nov 2007 21:04
#182678
The last time i replaced the carb gaskets in my bike, i took the old ones and traced out the pattern on a peice of a ceral box. It has worked well for me for about 3000 non leaking miles. It takes a bit of concentration but it can be done.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • Bluemeanie
  • Bluemeanie's Avatar
26 Nov 2007 05:25
#182693
I believe they are a type of cork. You can purchase just the bowl gaskets.
  • i800phyco
  • i800phyco's Avatar
26 Nov 2007 16:58
#182761
I've used plain old gasket paper in the past, you can get it at most auto parts stores.
Ham lake, MN.
77&78 KZ1000A's
A nice 79 1000LTD
And a pile 80 1000LTD
Plus a few others.
  • loudhvx
  • loudhvx's Avatar
26 Nov 2007 23:34
#182810
Most KZ550 A, C and D models use TK-22 carbs. The gasket is just paper. I put a super-thin layer of silver anti-sieze on the gaskets and they can be reused dozens of times. They are easy to make too. Make sure the float levels are right, after you re-build them. That also helps prevent leaks.
  • fishybass
27 Nov 2007 07:17
#182829
Thanks everyone for the thoughts. Gasket paper it is!
  • OKC_Kent
  • OKC_Kent's Avatar
27 Nov 2007 10:19
#182851
Would the anti-seize work on valve cover gaskets? I seem to get two removals of a gasket before it tears...:huh:
Cashion, OK
78 KZ650 B2 85,000+ miles
  • loudhvx
  • loudhvx's Avatar
27 Nov 2007 11:36
#182855
I use it on valve cover gaskets too. It prevents tears, but it's really because I hate scraping gaskets! I usually only use a gasket once or twice on the valve cover. I find after a few re-torques it's hard to get it to line up just right to seal. The surfaces have to be perfectly clean or it won't seal. I usually finish the surfaces to a polish with 400 or 600 grit sandpaper. I haven't had one leak yet, but I may just be lucky. The only place I may use a tiny amount of RTV is right at the cam-end plugs. The most important thing is to make sure and dig out all of the old sealant from the bolt holes. That debris build up and makes it real easy to strip a bolt.
  • arobsum
  • arobsum's Avatar
27 Nov 2007 17:01
#182890
this is the same thing i did about 3 years ago...so far, no problems.
