What are these?????
- otakar
24 Nov 2007 18:40 #182512
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
What are these????? was created by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
24 Nov 2007 18:41 #182513
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Replied by otakar on topic What are these?????
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- RetroRiceRocketRider
- Thank you received: 29
24 Nov 2007 18:49 #182517
by RetroRiceRocketRider
Replied by RetroRiceRocketRider on topic What are these?????
otakar wrote:
I'm gonna take a stab at it....motorcycle carbs? :silly: :laugh:
I'm certainly no expert, but judging from the angle of the float bowls and the shape of them, they look like a set of 33mm semi-down draft carbs.
Can anyone identyfy these carbs?
- otakar
24 Nov 2007 19:00 #182522
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
OK I guess I asked for that one:silly: :whistle: :blush: At least you did not say they are MIKUNI carbs.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
24 Nov 2007 19:04 #182523
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
How about you "WiredGeorge", can you help?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- wiredgeorge
26 Nov 2007 06:16 #182702
by wiredgeorge
Replied by wiredgeorge on topic What are these?????
Those things are from a later water cooled crotch rocket. Probably a GSX-R 600 or 750 or ZX600 type bike. like from the late 80s to mid-90s? I don't keep specs or ID info for those things as I don't get much call for rebuilding/sales. I have about 5 or 6 sets of them. The carbs are from bikes where the engine is tipped forward a lot farther than older air cooled Suz or Kaw models. This is the reason for the float bowl being at an angle. The spacing on those carbs is SIMILAR to the spacing on the KZ650/750/900/1000 engines and you CAN fit them to these bikes. I messed around with a set for a day or so and never could get them to run right. I think the bowls were running dry as the floats likely didn't work as they should because of the angle. I spoke with others who tried to make them work on the older air cooled engines without any luck. The pilot jets on those things are kind of smallish for CV carbs... #32 as I recall and the mains are not terribly large and that is why I think they may be from smaller displacement sport bikes. If you really want to figure things out, get the jetting info (hopefully it is still stock) and then start looking on bikebandit.com to see if you can match the jetting to some of the flatslides used on small displacement sport bikes (already mentioned models I suspect).
- tjk
03 Dec 2007 09:01 #183664
by tjk
FIDO
Replied by tjk on topic What are these?????
If the spacing is close enough to work on a KZ, they're not from a water-cooled bike. Those look pretty similar to the 29mm CV flatslides I have on the KZ650, which came from a first-year, air/oil-cooled GSXR750. But several other sizes and types of CV-flatslide Mikunis look similar, though the later-model ones I've seen have a remote (cable-operated) choke instead of the pull-knob on the carbs.
FIDO
- tjk
03 Dec 2007 09:12 #183665
by tjk
FIDO
Here's a pic of my 29s on the bike. Yes, they're nasty-looking, and will soon be removed to be cleaned-up. These carbs REALLY woke-up the 650. It likes them very much. They had a dynojet kit and air filters when I bought them for $55 off ebay.
FIDO
- tjk
03 Dec 2007 09:37 #183667
by tjk
