Carb problem or ?
- coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- 1982KZ1100D1
DRY test
1) 152
2)145
3)150
4)160
Post edited by: 1982KZ1100D1, at: 2007/12/02 15:53
- 1982KZ1100D1
Post edited by: 1982KZ1100D1, at: 2007/12/02 17:42
Post edited by: 1982KZ1100D1, at: 2007/12/02 18:03
- Thank you received: 2098
. . . check your compression . . . and adjust your valves. . . if valve clearances are too tight, the valves won't open enough for combustion to occur... especially when the engine warms. We have a "VALVE CLEARANCE" tech article as well that might help there.
And steell also suggested the same.
Perhaps missed, but have valve clearances yet been checked? Given the relatively low mileage, wouldn't be surprised if they had never been checked. And this should be done before any carb adjustments.
Post edited by: Patton, at: 2007/12/02 19:24
Post edited by: Patton, at: 2007/12/02 19:27
- 1982KZ1100D1
- wiredgeorge
I can't recall what all has been done with the ignition but if you have no vacuum in #4, let's look at the ignition just a bit. Swap 1 and 4 plug wires and see if the problem moves.
... no vacuum reading on #4 carb... backfires on acceleration
Would concur that good compression figures indicate valves are properly sealing, at least before the engine reaches normal operating temprerature.
Sometimes compression readings may look okay, but drop quickly after a short run. May be caused by insufficient valve clearance (gap). As engine warms, valve clearance reduces. And may reduce to the point where the valves are unable to completely close. Then it becomes a "leaking" valve (which drops compression).
So even where compression testing figures read okay, proper valve clearances are also necessary to maintain the compression at normal operating temperature. Note the periodic maintenance chart calls for checking valve clearances every 8000 km (or 5000 miles).
Even a perfect ignition with perfect carbs won't compensate for inadequate compression due to a leaking valve at operating temperature (regardless of cold compression figures).
Would pay particular attention to #4 intake valve, as this might possibly explain lack of vacuum on #4 and/or backfiring through leaking intake valve back into the carb.
The valve clearances may check out just fine -- hope they do -- and be thereby eliminated from the list of suspects. Besides, it's easy and will keep Ma Kaw happy.
Just my thoughts in looking forward to a beautiful bike running as good as it looks.
- wiredgeorge
- 1982KZ1100D1
Yes checking the valves is a "Must do" before it hits the road. I also think it's getting closer to a fix because of everyones help here. Even if it means pulling the carbs again it's better than having to replace rings or valves. I'll post what I find next weekend after checking the valves. I think my feeler gauge only goes down to .003 or .004in. but I would like to get them to the higher side anyway.Patton... You are probably right... no point by-passing must-do maintenance... Sounds like the bike is getting pretty close to being OK to ride.
- wiredgeorge
- 1982KZ1100D1
- 1982KZ1100D1
