A bunch of carb/air filter questions
- fishybass
24 Nov 2007 09:00 #182457
by fishybass
A bunch of carb/air filter questions was created by fishybass
This may be a series of stupid question from a newbie.
Air filters can be cleaned, right?
I started cleaning my carbs last night and discovered a couple of the o-rings were dried out and brittle. They need replacement. I was able to carefully separate the gaskets from the bowls and the carb covers. They are in good shape.
I am trying to avoid the cost of $100 for all new gaskets/o-rings as part of a carb overhaul set I don't really need.
1. Can I reuse the gaskets if I seal them with some RTV or similar?
2. Can I buy just any rubber ring of the same size?
I am guessing not on question 1. But I think I can save a chunk by making my own gaskets. Are their any suggestions for materials. They look like paper gaskets?
Lastly, is it normal for two of the choke plates to have a little trap door type thing in them, and two to not have this trap door?
Any help or advice on any of the above would be great.
Thanks!
Thanks!
- MadKaw500
- Thank you received: 5
24 Nov 2007 09:16 #182458
by MadKaw500
Replied by MadKaw500 on topic A bunch of carb/air filter questions
you can trace the gaskets carefully on a cereal box. a little trimming and being carefull they work good.check your local parts store for the o-rings, you'll just have to match them up.
