Looking for airscrew part
- crewzzn88
16 Jan 2006 22:09
Hello, I love this site!
I'm looking for the the small rubber o-ring that goes on the airscrew shaft. Mines are all worn. My bike is a 1979 KZ650 SR, VM24SS Mikuni's with a accel. pump.
Thanks!
Post edited by: crewzzn88, at: 2006/01/17 01:12
Post edited by: crewzzn88, at: 2006/01/17 01:15
Thanks!
- Sandy
- Fly High,Tony
Re: Looking for airscrew part
16 Jan 2006 22:19
Get a hold of Jeff at Z-1 Enterprizes(Jeff Saunders...Member here)
Awesome Guy to deal with,and can probably help You out.
Here's a link to one of the sections on His sight...take a look around...
And welcome to KZrider,Bud.
www.z1enterprises.com/catalog.aspx?pid=KPCF0
1977 KZ1000 A-1
- crewzzn88
- JMKZHI
Last edit: 03 Dec 2008 20:08 by JMKZHI.
- wiredgeorge
18 Jan 2006 11:56
While the Harbor Freight o-ring kits are made of nitrile and will hold up fine, I wouldn't use them for either the pilot fuel mixture screws or air mixture screws as the SAE sizes tend to be too thick when the ID is large enough to fit over either type screw and as a consequence, don't fit correctly. I have several Harbor Freight kits but use the correct o-rings for replacement when doing rebuilds as sealing the air mixture screws or pilot fuel mixture screws is ESSENTIAL for a good seal. The o-rings in the Harbor Freight kit work great for other purposes where an air seal isn't needed. Harbor Freight makes a metric o-ring kit and these are a bit more useful than the SAE sized kit with the funky R-0 to R-16 sizes (something like that anyway).
