kz750 chugging and stalling
- juangonzo
This is the first time I have ever worked on a bike (or any engine for that matter) so if I say something that doesn't make any sense, don't be surprised.
Also, I got a vacuum gauge to check if the carbs were synced but I have no idea where to connect it. Does anyone know where the connection for that is on the kz750s?
- Biquetoast
- King Jeremy The Wicked
So what were they set at? They should be *around* 1.5 turns out, but mine are more like a little less than 2 turns out......so I decided to turn the adjustment screws all the way in to count where they were. After turning them out to where they were my bike started chugging and stalling any time it gets going over 5 mph.
You see that little black hose that is connected *between* the two carb manifolds? You pull off that hose, and use the two brass nipples that are there. Oh, and make sure that hose is okay when you put it back.Also, I got a vacuum gauge to check if the carbs were synced but I have no idea where to connect it. Does anyone know where the connection for that is on the kz750s?
Also, this is weird... you're the second guy on this forum to buy a 750 twin that lives nearby me... what's going on? Was there a sale running on 750 twins?
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
- Shoe48
- Live each day as it is your last
- Thank you received: 5
- Biquetoast
As a rule I always check ignition first especially ...
Good advice.
My top three rules to new 750 twin owners:
1.) Investigate/dismantle/inspect your starter clutch to make sure it's not an engine lock-up waiting to happen
2.) Do the Coil-power mod
3.) Replace the coil. Just do it. Get a Dyna from z1Enterprises.com for $70, or something else, but just do it
4.)........ and so on...
kz750twins.com
- juangonzo
What should I look for while doing that?
My screws were set to 2.5 turns out. I turned them in to 1.5 and the bike is idling a lot better but still chugging to the point where 5 mph is my top speed.
Before messing with my bike my spark plugs were bright white. Now, they are really sooty. I think the cold weather has killed my battery, I have been using the kick starter for the past month or so because my battery doesn't have the power to even run the headlight.
I am looking at the coil mod and it looks pretty easy, I'll definitely do this over the winter. However, my wife is starting a grad school program and money is pretty tight so I don't see myself replacing the coil.
- wiredgeorge
- juangonzo
The bike was tuned up and checked over professionally about 2,000 miles ago and has 15,000 miles on it total. I will look into doing the full tune. Thanks for the help so far.
- Thank you received: 2829
