Ultrasonic Carb body cleaning
- Zed or Zee
19 Nov 2007 17:09 #181777
by Zed or Zee
Ultrasonic Carb body cleaning was created by Zed or Zee
What solutions do you use when cleaning non-painted carb bodies in an ultrasonic cleaner? Any recommendations based on past experiences?
- phonex98
19 Nov 2007 17:45 #181784
by phonex98
Replied by phonex98 on topic Ultrasonic Carb body cleaning
i dont have any experience cleaning carbs in an ultrasound machine, but i do use one in the labs for cleaning glassware and other devices.... theres no reason water wouldnt work. The only purpose of the liquid is to transmit the ultrasonic waves to the carb! ... although if its possible, i bet carb cleaning solution in the ultrasound would be pretty damn effective! Or something else that could dissolve gasoline like an alcohol or diethylether.
- FloridaBiker
- Thank you received: 4
20 Nov 2007 05:29 #181837
by FloridaBiker
Replied by FloridaBiker on topic Ultrasonic Carb body cleaning
You want to use a soapy solution for best effect.
I like Purple power, which I buy in 5 gallon jugs from Advance Auto Parts.
- FloridaBiker
20 Nov 2007 05:30 #181838
by FloridaBiker
- Zed or Zee
21 Nov 2007 06:17 #181996
by Zed or Zee
Replied by Zed or Zee on topic Ultrasonic Carb body cleaning
Thanks for the responses. I tried just water and it worked well. I will see if I can find some Purple.
