rebuilding 28mm
  • jus1975
  • jus1975's Avatar Topic Author
  • www.tripleaperformance.com
rebuilding 28mm
08 Nov 2007 20:41
#180231
I am restoring a 73 z1. I wanted to rebuild the carbs. Where can I find the parts. I want to replace everything that needs replacing and make these things look and run like new.
Also, I saw some tools and stand just for carb rebuilding. Does anyone know where I can find these tools.
Re: rebuilding 28mm
09 Nov 2007 10:02
#180300
Here's the Z1 carb related parts at Z1E :)
Z1E
Would also look at Z1E's tools section.
Am unfamilar with any type "stand" for carb rebuilding. :unsure:
  • Skyman
  • Skyman's Avatar
Re: rebuilding 28mm
09 Nov 2007 10:30
#180315
As for the stand, seems to me someone once posted pics here of a homemade stand they had built using a piece of plywood with old intake manifolds bolted on. IIRC, they then just secured the plywood using a bench vise.
I tried searching for the thread, but couldn't find it. Sorry.
Post edited by: Skyman, at: 2007/11/09 13:31
West Linn, OR
Re: rebuilding 28mm
09 Nov 2007 13:25
#180340
Skyman wrote:
...As for the stand, seems to me someone once posted pics here of a homemade stand they had built using a piece of plywood with old intake manifolds bolted on. IIRC, they then just secured the plywood using a bench vise....
NONB's jig
  • Skyman
  • Skyman's Avatar
Re: rebuilding 28mm
09 Nov 2007 14:49
#180351
Patton wrote:
NONB's jig
Yep, that's it. Thanks.
West Linn, OR
