mechanical synch question
  • kzmason
  • kzmason's Avatar Topic Author
15 Jan 2006 12:15
#18013
After reading through the manual and searching the forums here I still have a really dumb newby question. When setting the slide heights with a wire or whatever, are you doing it from the front or the back of the carbs?
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: mechanical synch question
15 Jan 2006 12:53
#18019
It's my understanding that you do it from the Back/Air Cleaner side. The 1000 could be different than the 650 though.
Where's are 1000 Carb Gurus?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • The Fish
  • The Fish's Avatar
15 Jan 2006 15:50
#18043
You set the carbs from the engine side. I have found that the smaller the tool (drill bit,etc)the closer the sync.
Fish
  • kzmason
15 Jan 2006 19:00
#18081
Awesome, I used a 1/16" drill bit (smallest thing I had w/ a consistant diameter)
