Broken Choke Lever Parts?
- HerrDeacon
05 Nov 2007 17:36
Hi, I was just cleaning the outside of my carbs and noticed that two parts on one of the carbs were broken. I'm not sure of their correct names but one is a lever that is attached to the rod that the choke lever turns and the other is attached to a plunger that makes it go up and down in relation to the lever I just mentioned. The lever connects to this part, it looks like a small plastic spool.
Can these parts be bought separately anywhere? I tried searching but it's hard when you don't really know their correct names. Or will I have to make them some how?
I've attached a picture to show the parts. The two red arrows point to the broken parts.
Any help would be appreciated.
Post edited by: HerrDeacon, at: 2007/11/05 20:43
- RonKZ650
Re: Broken Choke Lever Parts?
05 Nov 2007 18:47
They should be all over the place used off junk carbs. Otherwise you are looking for a starter lever 16046-007 and a collar 16073-014.
- HerrDeacon
06 Nov 2007 03:00
Thank you very much RonKZ650, that is a great help. Not aware of many junk places around here for bikes but I'll look. If I can't find anything I'll see if I can order them.
Thanks again.
Thanks again.
- Bluemeanie
06 Nov 2007 07:07
Keep an eye on ebay also, carbs all the time. I've thought about another old set just for parts!
Also just found this.... tinyurl.com/3y9dlq
Comes with aluminum choke plunger collers!!
Post edited by: Bluemeanie, at: 2007/11/06 10:12
- HerrDeacon
06 Nov 2007 10:16
Thanks Bluemeanie, good idea. That set you posted is nice too. Good idea to have aluminum collars, seems weird they would use plastic!
Thanks.
Thanks.
