carb rebuild found missing parts!?!? kz650
- cannibal440
31 Oct 2007 21:23
i got some rebuild kits for my kz650. i put all the parts in and as i was inspecting each carb i noticed that one of my carbs was missing this retaining clip and a small brass needle. the part is in the accelerator pump circuit. anyone know where i can get this part?
- otakar
Re: carb rebuild found missing parts!?!? kz650
01 Nov 2007 03:32
cannibal
If you are talking about the tiny little wire retaineng clip which holds the little ball and plunger which is actually a check valve in the float boal, I also had one get away on me while cleaning it with high preassure air. I bought a couple of thhem at Bikebandit.com from the OEM Kawasaki listing. They are a couple of $ each.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- cannibal440
01 Nov 2007 08:32
yeah youre right. little wire clip, brass needle with a ball bearing. thanks for the shopping tip!
