Vacuum petcock rebuild
- Bluemeanie
31 Oct 2007 13:56
I'm sure you guys have run across this. I'm rebuilding my vacuum petcock and after assembling it I can't turn the lever to save my life! The new dry "o" ring and rubber gasket for the selector valve won't allow it. Is there something that can be used as a lube? Thanks...
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Bluemeanie
Re: Vacuum petcock rebuild
31 Oct 2007 14:03
Maybe... have to be careful what you use. Could affect the rubber, swelling, etc. Let's see what other guys say. Thanks Skyman..
- Skyman
31 Oct 2007 14:25
Pretty sure spray silicon lube is rubber friendly. Someone feel free to correct me if I'm wrong.
West Linn, OR
- Bluemeanie
31 Oct 2007 15:08
I just finished putting it back on the bike. I ended up using a very, very thin layer of wheel bearing grease. It is petrolium based, so will blend with gas just fine. Getting the new "o" ring to stay in the groove where it seals against the tank was interesting, but I got it. No more leak! Thanks...
- jaguar
04 Nov 2007 19:17
Hey Blue, Where did you find the petcock rebuild kit? I need 2. Joe
- Bluemeanie
05 Nov 2007 07:49
Joe, there on ebay all the time. It's like $23+shipping. I'm sure Z1 has them also. There are a couple differant kits offered so just make sure it covers your year and make! Mine was a K&L kit which seemed to be the #1 choice on this forum!
Post edited by: Bluemeanie, at: 2007/11/05 10:50
