flat spot
  • zaptaliptica
  • zaptaliptica's Avatar Topic Author
flat spot
28 Oct 2007 18:23
#178567
i have a 78 kz 650 kerker 4 into 1 exhaust and pod filters just installed 110 mains and raised the needle to the highest notch and it will idle fine but when i give it any throttle it boggs down and then around 4 grand it picks up and revs just fine i cant tell if im running lean or rich or i have a leak or what but any input should be helpful and also it pops out of number four carb but i have adjusted the timing and it is right on so i don't know what would cause that any ideas would be helpful thanks
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
Re: flat spot
28 Oct 2007 18:31
#178568
'85 GPz550(ZX550-A2)
  • zaptaliptica
Re: flat spot
28 Oct 2007 18:48
#178569
thanks for the input i shall put it to the test maybe tomorrow if i get off of work at a decent time :pinch:
