Vacuum gauges -v- Manometer
  • rdgrnr
  • rdgrnr's Avatar Topic Author
23 Oct 2007 04:31
#177751
Does anybody have some advice on which I should use? I am thinking about a purchase for either one this winter as I have 2 bikes to synch this spring. (maybe more if this KZ bug keeps bitin'):S
I like the easy use of what the Morgan Carbtune Pro seem to be, and at about $130 delivered it seems reasonable. But I also see Z1 has the vacuum available for $50. Any help would be great...Thanks
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
  • oldcoldankles
  • oldcoldankles's Avatar
Re: Vacuum gauges -v- Manometer
23 Oct 2007 06:53
#177767
I considered both but felt the gauges would be harder to read and compare quickly so I bought the Morgan Carbtune, and made a very simple adjuster tool. Very pleased with it and can synch the 4 carbs very quickly just using the gas in the bowls.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
  • wiredgeorge
  • wiredgeorge's Avatar
23 Oct 2007 06:54
#177768
The only advantage one type of gauge has over the other would be the availability of mercury in the future if the set you are talking about uses mercury. I think mercury will become more regulated and not available as easily in the event it gets spilled out of a set of gauges as mercury has environmental impact. I think mercury gauges are the easiest and most accurate to use but we have stopped buying them because of the mercury concern. We now use non-mercury gauges with a sophisticated dampening system and they work about as well but without mercury tubes. The gauges we use are dial type gauges and pretty accurate.
  • rdgrnr
23 Oct 2007 10:55
#177815
wg,
I see that Z1 also has the dial gauge set with the dampers at about $185. Is that the system you use?
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
  • mariozappa
  • mariozappa's Avatar
23 Oct 2007 11:06
#177817
I got the dial gauges from jcwhiteny a couple of years ago for about $40. Looks like the price has gone up a bit.
www.jcwhitney.com/autoparts/Search?catal...10101&sku=carb+gauge
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • wiredgeorge
24 Oct 2007 06:02
#177873
Z1E and I both are K&L Supply dealers. I am likely using the one you refer to... it is a K&L shop quality dial gauge and not the one pictured in JCW. I use K&L Supply shop tools almost exclusively.
