Have u tried 34mm CV carbs?
  • Nelson
  • Nelson's Avatar Topic Author
15 Oct 2007 13:43
#176276
I'm thinking a set of 34mm CV carbs from a police bike or 80s KZ might give me more flow while still being civilized for lower rpm street use. They're also not too pricey on ebay...
Anybody tried this?
78KZ1000
Post edited by: Nelson, at: 2007/10/16 11:29
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
  • otakar
  • otakar's Avatar
Re: Have u tried 34mm CV carbs?
21 Oct 2007 05:16
#177347
Should work perfectly. this is the same carb used on the first j motors and the MK-II motors which are no diferrent from the 77-78 motors. You should get better fuel economy during normal riding but "may" loose a little "snap" in the throtle response. I believe you did nothing wrong. I would recomend matching the intake port casting to match the new boot you require for the CV carbs.
Here is a picture of my newest project which is almost finished. It is a GPZ made out of a CSR Cruiser. The CSR has the same carbs you are useing.
Otto Kudrna
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
21 Oct 2007 06:34
#177355
otakar is right on.imo there is no point spending $500 on vm29mm smoothies these days. there are now way more options, and price plays a majore roll. aparently there is very little performance dif between the 2.but if u are searching ebay keep an eye out for some 31mm Kehins, or rs34mm mikuni's($300 to 400). both would be a step up from the cv's for the reason otakar mentioned,responce. u can use j model boots for all.hope this helps .good hunting.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • wiredgeorge
  • wiredgeorge's Avatar
22 Oct 2007 06:55
#177536
The MK II engine did NOT use BS34 constant velocity carburetors... that bike model used VM28 w/accelerator pump. First BS34 was used in 81 on the J motor which is NOT the same as the MK II engine... lots of family similarities but a totally different engine.
The RS family of carburetors is a racing application and not necessarily better than a constant velocity carburetor on a street bike. The BS series carburetors are smooth and offer good performance with economy. To make the switch, you will need to use different carb holders, a different throttle cable and different air filter set up... See our website which has comprehensive install how-to written up on switching from VM to BS series carbs. Under "wg's Tech Stuff Index".
  • Nelson
22 Oct 2007 15:25
#177645
Great tips! I'm glad to see that other people have had the same idea. thanks for the info WiredGeorge!
