- Thank you received: 2
New float bowl gaskets. Leaks
- kwakagoose
11 Oct 2007 16:33 #175770
by kwakagoose
New float bowl gaskets. Leaks was created by kwakagoose
I just put a new set of float bowl gaskets on a 78 Kz1000 and they seem to leak. Has anybody ever had problems with new float bowl gaskets? Do they need doubling up? :huh: :blink:
Post edited by: kwakagoose, at: 2007/10/11 19:33
- Bluemeanie
- Thank you received: 14
11 Oct 2007 16:36 #175771
by Bluemeanie
Replied by Bluemeanie on topic New float bowl gaskets. Leaks
My new gaskets leaked too, after they soak up some gas try snugging them up again. Kinda like retorqing headgaskets. Worked for me...
- harm
- Tom
- Thank you received: 13
11 Oct 2007 17:21 #175783
by harm
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Replied by harm on topic New float bowl gaskets. Leaks
I had this too! My old ones were still in decent shape so put them back in and no more leaks. The new ones that were leaking were not Kaw gaskets so that may have had something to do with it...
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- Thank you received: 2098
11 Oct 2007 17:57 #175794
by Patton
Replied by Patton on topic New float bowl gaskets. Leaks
Please delete this post.
Post edited by: Patton, at: 2007/10/11 21:20
Post edited by: Patton, at: 2007/10/11 22:14
11 Oct 2007 18:02 #175797
by Patton
Post edited by: Patton, at: 2007/10/11 21:21
Post edited by: Patton, at: 2007/10/11 22:15
11 Oct 2007 18:07 #175799
by Patton
In previous postings ---
Jeff Saunders wrote:
One problem I've seen on several sets of these old carbs is where previous owners have overtightened the float bowl screws and distorted the carb body - essentially pulling the corners of the float bowl mount area downwards - often a visual look will see the corners slightly bent downwards.
In cases like this, the gasket can't easily do it's job - I know a couple of customers have double-gasketed the float bowl in an attempt to stem the weeping.
And baldy110 wrote:
I've worked on several carbs with the bent float bowl corners. I could never get the bowls to seal. I placed the bowls upside down on on open vice and lightly tapped the bottom with a hard plastic hammer. They slowly bent the corners back. They sealed after that.
Sometimes a leaking fuel pipe joint is mistaken for a float bowl gasket leak. Or leakage from a cracked or deteriorated fuel line, or loose fuel line connection.
11 Oct 2007 18:20 #175804
by Patton
Post edited by: Patton, at: 2007/10/11 21:22
11 Oct 2007 18:24 #175807
by Patton
Post edited by: Patton, at: 2007/10/11 21:36
11 Oct 2007 18:26 #175808
by Patton
kzrider.com/component/option,com_joomlab...w/catid,3/id,140533/
Memo -- Sorry, have no idea why these links are failing.
Post edited by: Patton, at: 2007/10/11 21:38
11 Oct 2007 18:35 #175810
by Patton
archaicbiker
Member
Carb bowl fuel seepage - 2007/05/15 23:10
I cleaned and sync carbs and shes running pretty darn good. My problem is im getting some fuel seepage past the bowl gaskets even though they are new. Any tips/tricks etc to fix this problem?
Bensalem, PA
07 m109 "Shamu"
06 Katana 600 "Echo"
77 xs750 (looking for new home)
79 kz1000 (looking for new home)
Sandy
Member
Re:Carb bowl fuel seepage - 2007/05/15 23:26
Are You SURE that the fuel is coming from the BOWLS...and not the "T-Fittings" that join the carbs together,or the fuel-line t's?
The fuel will leak from those fittings,and build up on the bowls,making You think it's the bowls that are the culprits...be sure.
N0NB
Moderator
Re:Carb bowl fuel seepage - 2007/05/15 23:30
To add to Sandy's point, gas will follow all sorts of contours and obscure its point of origin.
I have used Teflon tape to improve the seal on those tee fittings which usually seem to become worn down over time due to movement.
Nate
Sandy
Member
Re:Carb bowl fuel seepage - 2007/05/15 23:41
Exactly what Nate said!
On My old 26mm carbs I was using,I too,used the teflon-tape and it worked like a charm for 2-3 seasons,before I switched to the 29mm carbs.
Patton
Member
Re:Carb bowl fuel seepage - 2007/05/16 01:07
If new fuel pipes are desired, they are available from Z1E -- fuel pipe
austin3119
Member
Re:Carb bowl fuel seepage - 2007/05/16 02:27
Nice, I keep on wondering where the fuel is leaking on my 26's . I think I will pull them off and try the teflon tape.
I know this thread wasn't intended for me, but I think it is going to help me. Thanks.
Jeff.Saunders
Member
Re:Carb bowl fuel seepage - 2007/05/16 06:28
jeff@z1enterprises.com . . . . www.z1enterprises.com/?source=kzrider . . . . Upstate NY
baldy110
Member
Re:Carb bowl fuel seepage - 2007/05/16 12:27
archaicbiker
Member
Re:Carb bowl fuel seepage - 2007/05/16 22:50
Thanks for all the replys. The tees looked almost new but I will check them anyway. Its more likely the bent corner thing since the screws were so tight and they were leaking around the bowl when I took them apart. I guess I shoulda checked it out while I had them apart. I took my time cleaning and setting the carbs but got excited when it was time to put the bowls on and fire her up. She runs really good now, I just hate to take her back down but I cant have my son riding a fire hazard. Thanks for the help!
Post edited by: Patton, at: 2007/10/11 22:10
Post edited by: Patton, at: 2007/10/11 22:12
Member
Bensalem, PA
07 m109 "Shamu"
Sandy
Member
N0NB
Moderator
Nate
Sandy
Member
Patton
Member
austin3119
Member
Jeff.Saunders
Member
baldy110
Member
archaicbiker
Member
- wiredgeorge
12 Oct 2007 05:57 #175869
by wiredgeorge
Replied by wiredgeorge on topic New float bowl gaskets. Leaks
I have the bowl gaskets we used manufactured for us. The correct paper MUST be used. I have purchased gaskets in the past that were cut using the wrong paper... this usually means that the paper is too thin. The seller does this because the thinner paper is cheaper. The thinner gaskets LEAK. If you have this type leak, double gasket to stop the leak. The small screws that hold the bowl shouldn't be over-tightened... This usually will not stop leaking anyway.
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
12 Oct 2007 06:09 #175871
by riverroad
Replied by riverroad on topic New float bowl gaskets. Leaks
Anybody considered using an old gasket as a template and cutting some new ones from thick cork gasket material? They don't look like they'd be all that difficult. I've done it with outboard carbs before.
