Leaking petcock
- kz650csr81
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
My first KZ was a 440LTD with a vacuum petcock. Rode it for about 10 years before I sold it and bought a KZ1000 with a manual petcock. I had the hardest time getting used to turning the darn thing off when not in use. I was so used to the set-n-forget vacuum type.
Soon after getting the "new" bike, I swapped out the stock "LTD" tank for a bigger tank off of an A2A. It had a vacuum petcock, which of course leaked badly. Rather than rebuilding the leaky one, and taking a risk that it would still leak after rebuild, I ended up getting a new Suzuki petcock (available from Z1 Enterprises for less than $40), which bolted right on. Works perfectly, and I never have to fiddle with it.
For me, set-n-forget is the way to go.
West Linn, OR
- JMKZHI
- Thank you received: 48
- kz650csr81
Post edited by: kz650csr81, at: 2007/10/11 20:03
- JMKZHI
- Skyman
So those suzuki vacuum petcocks on Z1 will bolt right on huh.. that was something I was afraid of buying one of those and it not working right... well there it is vacuum all the way thanx.... on a side note A2A sorry new to the z world what kind of bike is that I have been hating the fact that I have such a small tank on my bike are those a direct swap? if so where can I get one?<br><br>Post edited by: kz650csr81, at: 2007/10/11 20:03
Sorry, I was referring to a KZ1000-A2A. It is a late '78 version of the KZ1000-A2. More info here: zedder.com/Info/78%20KZ1000-A2A.htm
The stock KZ1000 LTD ("B") tank has a capacity of about 3.5 gal. The A2A can hold abt 4.5 gal.
Actually, I am not completely sure the tank came from an A2A. I bought it on EBay, and just guessed on its origin based on its size and configuration.
I am not familiar with the KZ650, so I couldn't say if it would fit on your bike. I honestly doubt it though. Don't know if there are any other bigger 'stock' tanks that will just bolt on to a KZ650.
Regarding the Suzuki petcock, you should measure the distance between the bolt holes. If it is 44mm, it should just bolt on.
You may need to get "creative" on the routing of the fuel line, as the Suzuki petcock fuel outlet points straight back. On my KZ1000, that caused a problem because it pointed straight back to a frame post and left little room for the fuel line to bend down towards the carbs without kinking the line. I ended up just routing the fuel line straight back into a space under the front of the seat, then curved it back towards the front and through a hole that leads from the battery compartment back into the carb area. By doing this, I was able to avoid any fuel line kinks. You can read more about it and see pics in this thread: tinyurl.com/2p4r6h
West Linn, OR
- kz650csr81
- Spot
Good judgment comes from experience, which usually comes from bad judgment. - Will Rogers
- JMKZHI
- kz650csr81
damn thats cheap!! my dealer here in vegas wants $60 for all the parts...My local dealer in Norfolk, VA ordered the parts for my '83 KZ650 CSR petcock individually and it came to ~$30.00. Parts should be here in 3 days or so.
- twjoyce
