carbs dumping fuel?
- hammerdog
09 Oct 2007 20:09 #175488
by hammerdog
carbs dumping fuel? was created by hammerdog
The petcock is turned to the on position, and I go to fire up the bike. Fuel pours out the bottom of the bowls. Sticky floats? The bike is a '77 kz650B1.
- bill_wilcox100
- Thank you received: 5
09 Oct 2007 20:55 #175497
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic carbs dumping fuel?
Welcome to the forum hammerdog. Nice to have you here and that’s a great bike you have.
I assume that you mean that the gas is flowing out of one or more of the 4 float bowl overflow pipes. If so and if you are lucky, it may only be a matter of dirt and or rust from your gas tank lodged in one or more of your needle valves. Clean out your carbs, clean out your gas tank, add fresh gas and add a new in line gas filter between your petcock and the carb could solve your problem.
I had the same problem. I had to do four things to solved it.
1) New in line gas filter.
2) New needle valve kit in each carb.
3) Adjusted the level in the float bowl with a level detector.
4) Fresh gas.
If you don't have one, a shop manual will be very usefull for you. Let everyone know how it goes.
By the way, could you add your year, model and location in your signature to allow other members to better help you.
Best of success.
Post edited by: bill_wilcox100, at: 2007/10/09 23:58
Post edited by: bill_wilcox100, at: 2007/10/09 23:59
4) Fresh gas.
Best of success.
Upgrades:
Montreal, Canada
- hammerdog
10 Oct 2007 05:58 #175518
by hammerdog
Replied by hammerdog on topic carbs dumping fuel?
10-4, Thanks Bill!
- bill_wilcox100
10 Oct 2007 06:52 #175522
by bill_wilcox100
Upgrades:
Montreal, Canada
So, hammerdog... where are you at?
Post edited by: bill_wilcox100, at: 2007/10/10 09:53
Post edited by: bill_wilcox100, at: 2007/10/10 20:06
Upgrades:
Montreal, Canada
