carburetor order?
  • Skydivelife
  • Skydivelife's Avatar Topic Author
carburetor order?
09 Oct 2007 14:55
#175426
Hey guys,
I'm new here, hi!
I recently bought a '78 kz650 that has turned out to be kind of a lemon thus far. so anyway, I popped off the float bowl and top to the carb and saw a number one on 2 of the carbs and a number 2 on 2 of the carbs. How are these supposed to be ordered, or does it even matter? Do the ones go in the middle or on the outside?
thanks!
Nate
  • Bluemeanie
  • Bluemeanie's Avatar
Re: carburetor order?
09 Oct 2007 16:26
#175436
Are you talking about the float bowls and caps?
  • Skydivelife
18 Oct 2007 22:08
#177018
yeah
  • The Milkman
  • The Milkman's Avatar
18 Oct 2007 22:16
#177020
As long as the air adjustment screws on 1 and 2 are on the left and on 3 and 4 are to the right and the drain holes on the bowls are situated the same way as the screws it really doesn't matter. The PO may have taken them off the rack and mixed them up.
Ride safe
