Protecting tank during rebuild
- Link14
05 Oct 2007 08:50
I'm in the process of a major (for me anyways) rebuild on a 1982 KZ750-H3 and have pulled the fuel tank for better access to everything. I usually keep my tanks as close to full as possible to prevent rusting, but I'd like to empty this one to work on the petcock and fuel level indicator.
I'd appreciate any suggestions on what to use to protect the metal inside the tank while it's drained. I was thinking of just spraying alot of WD40 into the tank and swirling it around, dumping out the excess. Wasn't sure it this would give me any problems when I filled it again and tried to start it up.
Any other suggestions?
Thanks!
Thanks!
- Mcdroid
- Gone Kwackers
Re: Protecting tank during rebuild
05 Oct 2007 09:13
WD is the way to go...cheap and easy...when you are ready to reuse the tank, just dump in some gasoline, swirl and discard...and if a little WD remains, it won't matter...your bike will even run on this magic stuff.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
