To pump or not?
  • burnoutbob405
  • burnoutbob405's Avatar Topic Author
To pump or not?
04 Oct 2007 13:18
#174558
Hey everyone.
Im having trouble making a decision on which carbs I should use.
I have a 78' kz650 with what I believe to be the original carbs but I was recently given a set off a 79'.
The 79' has the accelerator pump and I figured that it could only improve the running condition but I just wanted a second opinion before I go buying rebuild kits for it.
I was also wondering how much I should adjust the air mixture screw seeing as how Im more in tune with the pilot screw. If there is anything else I should know about this model of carbs please let me know
Trent
  • Bluemeanie
  • Bluemeanie's Avatar
Re: To pump or not?
04 Oct 2007 14:38
#174572
The carbs are basically the same. They added the pump for better drivability due to leaner jetting. I have those carbs on my F1 and kits do not exist! The pump carbs require a different bowl gasket along with "o" rings. I had to come up with my own rings. Everything else is the same. I would say stick with the older carbs as they are much easier to work with. You can use the newer ones for any parts.
  • burnoutbob405
Re: To pump or not?
04 Oct 2007 19:16
#174608
Well, just to let you know, I did end up finding an accelerator pump kit on this site
crc2onlinecatalog.com/misc_carb_parts.htm#KAWASAKI%20Acc
I couldn't find a carb rebuild kit for that exact year but after looking it over they have almost identical jets.
The gasket differs slightly but other than that there the same I guess.
In the end, I guess I won't fool around with em seeing as to how its just more work and all with little or no improvement from what I have been reading.
Thanks
Trent
  • RonKZ650
  • RonKZ650's Avatar
Re: To pump or not?
04 Oct 2007 19:39
#174616
Actually the bowl gaskets are the same whether you have pump carbs or not. Same gasket was used on 1977-1979 KZ650, 77-80 KZ1000 and the KZ650F1 too. The oring on the pump carbs fits in a circular opening in the gasket which is there on all the bikes, even the regular 78 and earlier type.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: To pump or not?
05 Oct 2007 06:14
#174687
Ron is correct... all VM24 bowl gaskets are identical. The small oring described gaskets the spray nozzle inserted into each venturi.
As to whether the pump or non-pump carbs are "better", either will work fine but the pump adds another element of complication and if you own pump carbs, you had best know how to test them to ensure they work correctly and be able to repair any problems that inhibit their operation. If the pump doesn't work on a pumper assembly, the jetting is set up to work with the pump so the bike/carbs will not run optimally unless the pump is working right.
  • Bluemeanie
Re: To pump or not?
05 Oct 2007 08:02
#174701
Ron, maybe I got brand "X" kits (don't remember brand) but they did not have openings for o rings. Tried to cut opening but not enough material. I had to order proper gaskets.:)
  • RonKZ650
  • RonKZ650's Avatar
Re: To pump or not?
05 Oct 2007 10:33
#174723
I see what you mean. Those gaskets will not work. That's just the reason I try my hardest to stay away from anything aftermarket because this always happens. If you buy Kawasaki gaskets, they would have the cutout for the oring.
