WOW!!!!
- BoZ650
- 77 KZ650 with 4 to1 and pods,Dyna Coil and Dyna S
WOW!!!!
02 Oct 2007 13:51
So I started my KZ650 today for the 1ST time!And all I can say is wow!!!!!It has a 4into1 pipe and pod filters.I ran it with no baffle and the sound was just awsome(Kinda made me nervous!)I just want to go back to shop and start it again just to hear it!Anyway it seems to run fine and idles good but I pulled a plug (#4)and it was black as night!!!What should I check 1st.I havent sinc the carbs yet(I dont have guages)But they have 110 mains and 17.5 pilots with the throttle valves in the middle position.Should I drop those valves back down or try to adjust the air screws out more(Currently out 1 and1/2 turns.Im new to the old kz's so this is my 1st dance with these things!
77 KZ650 With 4 into 1 header,Air pods,Dyna Green coils,Dyna S Ignition and WiredGeorge coil mod!
- 77Davo650
Re: WOW!!!!
02 Oct 2007 14:16
Have you checked valve clearances? Timing? You say you started it but did you drive it around? I had the exact same setup (77kz650, pods, 4-1, 110 mains, 17.5 pilots, good compression and valve clearance in spec, carbs synched) and everything checked out but my plugs were a little black and sooty but only if I idled it in the garage and didn't do any good runs. Do a search in the forums for plug chop (killing the engine while going WOT or something close and then braking to a stop and then checking plugs, rather than just running it in your garage and then checking plugs) that will give you a better plug read to determine if you have any issues.
Yeah, starting it for the first time is a good feeling isn't it?
Post edited by: 77Davo650, at: 2007/10/02 17:17
77 KZ650 C1 (sold)
78 KZ650 B2 (sold)
78 KZ400 B1 (sold)
78 kz400 C1 (resto-mod)
78 kz400 C1 (hardtail low chop)
couple of possible project kz's in parts
78 KZ650 B2 (sold)
78 KZ400 B1 (sold)
- BoZ650
Re: WOW!!!!
02 Oct 2007 14:20
Thanks Davo.No i just got it all back together from a complete teardown to the frame.Its nowhere near ready to ride.Just got the engine and wiring hooked up and i couldnt wait to here it.I guess ill wait till i ride it thanks though!
- BoZ650
Re: WOW!!!!
02 Oct 2007 14:22
- The Gringo
- ¡Usted no necesita otra motocicleta!
Re: WOW!!!!
02 Oct 2007 17:24
On a bike that old checking the voltage at the coils would be a good thing to do. If they are reading low, do the WG coil repowering mod. You will save yourself alot of time chasing your tail trying to fix things that won't help if you have low coil voltage.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- BoZ650
Re: WOW!!!!
03 Oct 2007 03:12
Thanks Gringo,Ive been searching for the post with the wiredgeorge coil mod for a couple weeks now.The archives im really not good with.It asks for my password and such but never lets me in.I think becuase im a new member or the nut behind the wheel could be loose!!But I intend on doing that mod anyway to make sure coils are powered up at all times.But the bike ran nice to me (maybe becuase I dont know any better)The plugs were just black.Could that be becuase I had marvel mystery oil in the cylindersfor the last six months?? Plus the motor sat outside for at least 10 years.But anyway,black plugs means rich(too much fuel?),correct??????????
- The Gringo
Re: WOW!!!!
03 Oct 2007 03:25
Here is the link to George's website on how to do the coil mod.
www.wgcarbs.com/index.php?option=com_con...view&id=12&Itemid=26
You will save yourself a lot of grief and aggravation if you just contact parts-express.com that he mentions in the article as opposed to trying to buy a relay at an auto parts store.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- BoZ650
Re: WOW!!!!
03 Oct 2007 04:24
Thanks yet again Gringo!!Thats exactly what I wanted!!!I can get right after that now.
- OKC_Kent
Re: WOW!!!!
03 Oct 2007 04:32
BoZ650 wrote:
BoZ650,
In Archive searches you do not need to enter any password. Stein disabled all that stuff, just browse the different forums or click the magnifying glass at the top.
Don't worry about the plugs for now, your jetting sounds good for your setup. Stock is like 102.5 mains and 15's for pilots. The stock needle clip position is 4th down from the top. Once you get it running under a load and can do a plug chop then go ahead and fine tune the jetting.
Coil mod is worth it.
Nut behind the wheel? Aren't we all?:lol:
Post edited by: OKC_Kent, at: 2007/10/03 07:38
BoZ650,
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- BoZ650
Re: WOW!!!!
03 Oct 2007 12:59
Thanks OKC,
I tried the coil mod today and I had to step away from it,I have no patience for wiring!But Im 2/3 of the way done.Just gotta locate a couple of wires and make connections and im done.Ill get back at it tomarow.After that im changing my blinker fluid!(Joke!!)
- bemoore
Re: WOW!!!!
04 Oct 2007 10:58
Along with the coil repowering mod, I recommend replacing the fuse box with one designed for blade type fuses. I used one from Advance Auto which cost about $3, and less than $10 with fuses. If you're doing the coil repowering mod, you'll need to add a fuse somewhere. The new fuse box has 4 slots, and my old one had 3, so this worked out great. The new fuses did more to help the running of my bike than the coil power mod did. But I suspect that if I'd done the coil power mod first, I wouldn't have noticed a difference with the new fuse box.
77 KZ650C1 w/Kerker 4-1
- BoZ650
Re: WOW!!!!
04 Oct 2007 11:47
Now ya tell me!!!Thats a great idea.I know the exact fuse panel your talking about.Maybe when the bikes done and im starving for a project Ill take you up on that advice!!Thanks
