differant carbs
- 1cheapride
- JMKZHI
- Thank you received: 48
- 1cheapride
Thanks
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
'85 GPz550(ZX550-A2)
- z1rick
- Thank you received: 5
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
- wiredgeorge
- 1cheapride
- arobsum
- Thank you received: 10
then enlighten him........Since the 1980 KZ650 carbs were all mechanical slide and this fella put "new diaphragms" in, I suspect that no one has a clue as to what type carburetors he installed. There are no diaphragms in a 1980 KZ650 except for the accelerator pump and air cut of valve assemblies.
- wiredgeorge
- arobsum
like that! this answer was just fine.....Enlighten him? How so? He has accelerator pump VM24s which will fit on his bike just fine. All 24s have either air screws or pilot mixture screws or both. the pilot mixture screws are located on the engine side underneath in front of the float bowls. If they are not there, then the carbs most likely have air screws capped by aluminum plugs. There are about 20 versions of the VM24 carb assembly used on various KZ650 models.
