petcock pee when turn off bike
  • NIGHT RUNNER
  • NIGHT RUNNER's Avatar Topic Author
27 Sep 2007 08:36
#173166
hey guy's
hope you haven't been in this situation:
petcock leaks a little but every time i turn it off is sooth a squirt of gas.
may be a bad diaphragm?
i don't want to take it apart until i know what can i do in case thay the complete assembly is bad.
thanks in advance!
77 650b1
  • tjettim
  • tjettim's Avatar
Re: petcock pee when turn off bike
27 Sep 2007 09:24
#173169
Just order the diaphram and spring washer.
The 77 petcocks are simple to repair.
  • kz650csr81
  • kz650csr81's Avatar
27 Sep 2007 12:15
#173196
My petcock leaks slightly when the bike is off... no pee though.. where can I find the O-ring replacements and new spring and diaphram.. I spoke with local dealer and they can't even order.....
  • JMKZHI
  • JMKZHI's Avatar
Re: .
27 Sep 2007 12:56 - 03 Dec 2008 07:55
#173205
del
Last edit: 03 Dec 2008 07:55 by JMKZHI.
  • NIGHT RUNNER
29 Sep 2007 10:57
#173490
well,
i'll try the repair kit.it just sounds scary after hearing so many bad experienses with petcocks.
thanks for the reply to all!
NIght Runner
  • AR15Ron
  • AR15Ron's Avatar
29 Sep 2007 11:35
#173498
My petcock doesnt shut off at all.. it's an aftermarket Pingel.. Looked like it would need to be replaced since I couldnt find a rebuild kit fot it. I got 2 fuel shut offs from Z-1 and just open the seat and turn them off manually, so far so good. Unless someone knows where I can get a rebuild kit? My 93 Ninja 600 also leaks a little, thinking of doing the same thing :) At least they both work ON!
Ron
  • JMKZHI
  • JMKZHI's Avatar
Re: .
29 Sep 2007 13:24 - 03 Dec 2008 07:55
#173531
del
