Carb Overflowing
  • MrDonut
  • MrDonut's Avatar Topic Author
Carb Overflowing
25 Sep 2007 09:19
#172749
Hi,
I have a '77 kz650 c1, runs excellent the only problem is the interior clutch side carb keeps leaking out the overflow tube. I took the bowl off checked/cleaned the float+pin for problems-none, checked and cleaned the needle and seat under the float. Still leaks - Any ideas what may be causing this.
Any help will b appreciated- Jim
1977 KZ650 c1
  • OKC_Kent
  • OKC_Kent's Avatar
Re: Carb Overflowing
25 Sep 2007 10:10
#172761
Did you adjust the float? It may be set too high.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • wiredgeorge
  • wiredgeorge's Avatar
25 Sep 2007 12:24
#172789
Do you know how to spot a bad float needle? If not, replace them all. If the bike still leaks, then either that cylinder isn't firing sometimes (if leak occurs while bike is running) OR you need to adjust the float level; that is, adjust the level of gas in the bowl so that there isn't quite as much gas.
