gpz1100 injectors in head or throttle bodies
- 77KZ650
25 Sep 2007 07:44
just wondering what yrs had the injectors mounted in the head (looking to avoid these) Im getting a few conflicting statements and Im just wondering if some people are confused as to what yr of bike parts they have for sale. (ebay, forum members ect..)
I thought that the gpz1100 had the injectors mounted in the throttle bodies starting in 83....was it earlier?
thx a lot!
thx a lot!
07 MDP Rookie of the Year
- pstrbrc
- '81 GPz 1100 project
Re: gpz1100 injectors in head or throttle bodies
25 Sep 2007 07:56
The KZ1100B1 (1981 GPz) had the injector-in-head. The KZ1100B2 (1982 GPz) had injector-in-TB.
edit:
another major difference in the systems is that the early FI ('81 and earlier) didn't use a real throttle position sensor, just used a switch that told the "brain" when the bike was WOT. The '82 and later throttle bodies had a real TPS. The early TB's have the WOT switch on the left side, the later have the TPS on the right. This is a better reason to go with the later TBs, in my opinion. You can use an early head with later TBs, you just have to plug the injector holes in the head.
Post edited by: pstrbrc, at: 2007/09/25 11:01
edit:
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
- steell
25 Sep 2007 08:04
pstrbrc wrote:
Just to add to this:
The 80 KZ1000 Classic also had injectors mounted in the head.
The 80 Classic, the 81 GPz1100, and (I think) the 82 GPz1100 did not have proper TPS sensors, they were more of an on/off switch.
Go for 83-84 GPz1100 or 84-85 GPz750 Turbo.
Duplicate Info, pstrbrc edited his post while I was typing
I think the 82 GPz1100 had the on/off TPS also, because it used a mass air flow sensor, unlike the 83-84 models.
Post edited by: steell, at: 2007/09/25 11:08
- 77KZ650
25 Sep 2007 08:08
thx guys, I definatly need a set with the proper TPS aswell
- Mcdroid
- Gone Kwackers
25 Sep 2007 08:14
An additional area of confusion that I've seen on eBay is the FI apparatus from the KZ1000G1 (Z1 Special) This is also an 'injectors in the head' bike. BUT, the majority of the hardware differs from the later GPzs' the only part congruence being the actual injectors.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- steell
25 Sep 2007 08:28
The KZ1000G is the Classic I was talking about above
Never heard it called the "Z1 Special" before.
There is a MegaSquirt forum at www.cyclemadness.com/f that has become fairly active lately, if you are not posting there already then you might want to check it out.
- Mcdroid
- Gone Kwackers
25 Sep 2007 08:33
steell wrote:
Ah well...another senior moment:blink:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- 77KZ650
25 Sep 2007 08:44
steell wrote:
edit: updated sig
Post edited by: 77KZ650, at: 2007/09/25 11:52
I allready started a "project" thread there;)There is a MegaSquirt forum at www.cyclemadness.com/f that has become fairly active lately, if you are not posting there already then you might want to check it out.
edit: updated sig
