Got kz440 chop running and riding but need some help tuning
  • djnubz
  • djnubz's Avatar Topic Author
24 Sep 2007 12:10
#172579
I just got my kz440 chopper running and driving today. I have a few problems though. First the bike seems very underpowered. I used to ride a kz1000 and I know that that is a much faster bike but this bike seems to really be strugling to keep up with traffic. The bike is running open pipes, pods and is much lighter then stock, I would think that this bike would run a lot faster. Could I just be running very lean?
One of my carbs is draining fuel out the bottom of the carb (there is a nipple there). Is this because my float level is set wrong?
Is there anyone in the south FL area who is good with tuning these bikes? I am going to try myself but I feel someone who is a pro would do a better job.
There is a slight chance that I am not using the original carbs on this motor (came to me as a basket). The carb boots are larger then what is on a 82 kz440 I just picked up and the carbs are a we bit bigger as well. The carb boots don't match the head perfectly, could this be the cause of any problems? I don't think it is but I thought I should ask.
  • Dutch Masters
  • Dutch Masters's Avatar
Re: Got kz440 chop running and riding but need some help tuning
24 Sep 2007 12:24
#172582
Check your float level for the leak, and your spark advancer for the power. My advancer was was rusted shut, and the bike would not pull past 4K.
  • djnubz
24 Sep 2007 12:30
#172583
will check float later. I previously had to free the advancer as it was rusted before, it now turns freely.
  • lucas808
  • lucas808's Avatar
24 Sep 2007 13:14
#172587
I had alot of trouble with my carbs leaking too, changed to a different set with the same proble, turned out to be a combo of the gas lid not sealing and the petcock being bad, I would check those as well, just a sugjestion. B)
  • don_belt440
  • don_belt440's Avatar
24 Sep 2007 14:48
#172615
Would you mind posting some pics? I'm thinkin about choppin my 440 in the future (like next summer) and am looking for ideas.
24 Sep 2007 15:02
#172616
djnubz wrote:
...One of my carbs is draining fuel out the bottom of the carb (there is a nipple there). Is this because my float level is set wrong?....
More likely some crud at the float-needle/seat interface. Which is the main reason for an overflow function through nipple on bottom of float bowl. :)
  • djnubz
24 Sep 2007 15:24
#172620
I was told that I am probebly using the wrong carbs on my bike (keihin 36mm). Can these be jetted to work properly with my bike or do I need to find a new set of kz440 carbs?
www.flickr.com/photos/wildboynubz/
There are also pics of the chop on there.
  • wiredgeorge
  • wiredgeorge's Avatar
25 Sep 2007 06:14
#172722
Sure, it is possible to rejet the 36mm carbs to work with your bike. The reason gas is drooling out; if the bike is running, is that the cylnder isn't firing all the time. You can check the float level and clean the float/seat but it is more likely a combustion issue. CHECK YOUR IGNITION.
  • djnubz
25 Sep 2007 15:36
#172827
I should of mentioned it only leaks when bike is off so far. Wired the carb boots I am using don't exacly line up with the head on the ID. I would think this would cause a performance decrease. Would I be better off getting a set of the small carbs considering the boots I have to match them would line up perfectly? Do I have other options?
The motor vin starts with 440ae if that matters.
Some pics are here
<IMG SRC=" farm2.static.flickr.com/1322/1435301890_410a47a542.jpg ">
Post edited by: djnubz, at: 2007/09/25 18:39
