Revs great in neutral, flops and dies under load?
- ajohnson
23 Sep 2007 21:57
hi guys,
its a '77 kz650B, just chem-dipped and rebuild carbs with all new jets, everything stock setting. dyna ignition and coils new top end gaskets, rings, honed (not bored) the cylinders, lapped and adjusted the valves, uni pods, stock exhaust
so after the rebuild it ran great on the lift, and i was excited. it starts on the first kick and revs right up (as high as i dared while the rings seated). When i went to take it around the block, it bogs way down and sometimes dies as soon as the trans starts to engage, it is not so pronounced while rolling, but still noticable, and there is very little power.
I hope that this is a carb problem, because I feel ok about working on them (as opposed to the trans). I am at about 5000 ft. and like I said, i put the carbs back to factory settings. Is it better to adjust the pilot jet, the needle or both? Does this sound like something that a good carb tune could solve?
thanks
thanks
Re: Revs great in neutral, flops and dies under load?
24 Sep 2007 04:59
If not already done, would use strobe-type timing light to assure correct ignition timing, and especially to confirm proper operation of the advancer unit.
With advancer stuck closed, unloaded engine will rev seemingly okay.
Also, what do the plugs look like -- did they quickly soot up? If excessively rich mixture, could be problem in carb pilot circuit.
Do pilot screw adjustments have any effect? If not, also points to pilot circuit.
- wiredgeorge
24 Sep 2007 07:45
The air/fuel mixture in the pilot circuit is not correct... typically at 5K feet, it will be rich due to the thin air. Adjust the pilot mixture screws to fix the issue.
- ajohnson
24 Sep 2007 10:19
thats exactly what I wanted to hear WG. it looks like you are quite the carb guru around here, i will try this the first chance i get. thanks, aj
- ajohnson
24 Sep 2007 12:22
by the way, the mixture screw is on the airbox side, so it is an "air screw" right? which means i should adjust it out (not in) to allow more air into the mixture? or do i have it backwards?
Post edited by: ajohnson, at: 2007/09/24 15:23
- wiredgeorge
25 Sep 2007 06:16
Turn out the air screws to lean the mixture.
