Yay Carbs! another question!
  • hobodan
  • hobodan's Avatar Topic Author
21 Sep 2007 09:00
#171972
So I have these carbs:
Click for a bigger picture:
[img
[img
[img
[img
[img
[img
And i have no idea what model or anything they are. I was wondering if someone could help me out!
Here are the numbers I got off of it:
Carb #1 choke side:
N7
Y4
Carb #4
106
9A
Also I have a V&H 4 in 1 exhaust on it as well as pod air filters, could someone perhaps steer me in the right direction for the correct needles and jets?
Thanks A lot everyone!
Post edited by: hobodan, at: 2007/09/21 13:47
1977 KZ650-B1 frame and engine. Random pile of parts for the rest.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Yay Carbs! another question!
22 Sep 2007 17:09
#172233
Correct needles and jets? You have early VM24 carbs; probably the ones that came stock on your 77. Use #110 mains, #17.5 pilot jets and reclip your jet needles to the 4th slot with your set up.
22 Sep 2007 18:17
#172249
Someone appears to have mixed your carbs up. If you look at the brass fuel drain screws (Screw,Guide) on the carb bottoms, it looks like number 2 and 3 carbs have been switched. The screws on carbs 1&2 should face left 3&4 should face right. Wiredgeorge can tell you what, if any, problems this could create. Ed
  • hobodan
22 Sep 2007 18:36
#172256
Yeah, the covers on the bottom were in the wrong spot, but i fixed that. made it much easier to to drain! =P
VM24 huh? I was wondering if they were stock model or not, but i know they are not the ones that came with this engine, when i got the engine, it did not have any, and i got these off ebay for a pretty good price!
And will that setup be the norm or will it be a bit rich or lean?
By 4th slot does that mean 4th slot counting up from the slot closest to the needle point?
Also, where should i have the mixture screws set? 1 and a half turns out?
Sorry to ask so many questions, but I'm not exactly familiar with the carbs on these bikes.
Thank you very much!
Post edited by: hobodan, at: 2007/09/22 23:54
  • Bluemeanie
  • Bluemeanie's Avatar
23 Sep 2007 08:07
#172339
hobodan, slotting the clip is counting down from the top. Basic mixture setting for stock is 1 1/8 turn out for your bike. I believe your screws should be on the bottom? From stock setting you would turn each screw in or out slightly to achieve to highest idle, adjust all screws 2-3 times to achieve uniform results. Make sure you run a large fan to front of motor and gas it now and then. WG's recommendations will be real close, Good luck!
  • hobodan
23 Sep 2007 09:22
#172351
Thanks for the reply, the screws for this particular set are on the sides, a bit back from the filter side. but i will try that, thank you!
-Dan
