kz750E needle seats?
- Aggroton
20 Sep 2007 07:29
anyone know where i can get them?
haveing trouble finding them.
checked obb, z1enterprises, and sudco...
or am i just looking in the wrong places?
or the wrong part lol?
thanks guys.
thanks guys.
- JR
Re: kz750E needle seats?
20 Sep 2007 21:04
Are the carbs the stock Keihin CV34s ? If so then you can stop looking as the seats dont come out / cant be replaced. They can be cleaned up with carb cleaner on the end of a Q tip.
If they are damaged then you might have to look for a set of replacement carbs.
Hopefully the Q tip trick will work.
Post edited by: JR, at: 2007/09/21 00:05
- The Gringo
- ¡Usted no necesita otra motocicleta!
21 Sep 2007 04:05
I've had pretty good luck using some mothers mag polish on the end of a Q-tip to polish up brass carb seats. Makes them look like new.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Aggroton
21 Sep 2007 06:46
yeah tried the qtip twice...with mothers and with carb cleaner...no dice.
- JR
21 Sep 2007 16:54
What's the actual problem ? Scratched ? Chewed up ? Leaking?
Maybe time for steel wool + mothers
Probably a dumb question on my part but you did try new float needles ?
- wiredgeorge
24 Sep 2007 07:57
Many times when the Keihin float needles won't seat and leak, the problem is the needles should be replaced. While polishing the seats makes them look nice, it doesn't do much for sealing. As long as there is nothing on the edge of the hole in the seat; whether they are shiny or not doesn't make a difference but it doesn't hurt to clean the seats. The correct float needles for a Keihin CV34 have rubber tips and a small piece of wire that hooks over the tang on the float, I think. I would also check float levels and ensure the vents are unobstructed.
