Help me fix me bike
- Hightower
20 Sep 2007 07:12 #171739
by Hightower
Help me fix me bike was created by Hightower
As some of you may know, Im having probs with fuel staying in my bike 82'CSR650.
After reading some searches am gonna chance fixing it meself! A first ever ... :lol:
Not sure wot gear to get off Z1 Enterprises, woz thinking new petcock. But wot else??
Is there a step by step guide to removing the carbs? With pictures hopefully!! Cant think of anything else to say!! Cheers:whistle:
- z1rick
- Thank you received: 5
20 Sep 2007 19:51 #171878
by z1rick
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
Replied by z1rick on topic Help me fix me bike
Do you have a service manual? Usually the manuals have pics and step by step directions. That's how I learned the little knowledge I have:P Here is one on EBay:
tinyurl.com/2x6x9d
tinyurl.com/2x6x9d
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
- Hightower
20 Sep 2007 23:54 #171919
by Hightower
Replied by Hightower on topic Help me fix me bike
- 2M4Dale
21 Sep 2007 03:19 #171932
by 2M4Dale
Hello from Sunny Mansfield, Ohio
1980 KZ750H1 LTD
1981 KZ750H2 LTD
Replied by 2M4Dale on topic Help me fix me bike
A quality service manual is almost a must have !!! Don't waste your money on a Haynes manual ... shell out a few extra $$$ on a factory service manual ... well worth the extra cost !
I'm using those EMGO pod filters on my KZ ... they look great and should perform great as well. You might need some jetting changes though.
1980 KZ750H1 LTD
1981 KZ750H2 LTD
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
21 Sep 2007 07:19 #171955
by riverroad
Replied by riverroad on topic Help me fix me bike
Yeah, I just put some of those Emgos on my 80 LTD. And after riding it all day yesterday, I think I need to go up a jet size or two. But first I'm going to re sync my carbs.
Now I don't know what kind of carbs are on a 82 CSR650, but I ran across a thread that said the Emgo pods restrict some air passages on the face of the inlets, so watch out for that.
- wiredgeorge
24 Sep 2007 08:20 #172527
by wiredgeorge
Replied by wiredgeorge on topic Help me fix me bike
Keep in mind that if you switch to the Emgo pod filters, your carburetors will need to be rejetted. Since you haven't figured out how to remove them, I would hold off until I had a shop manual in hand and sufficient expertise to remove the carburetors before choosing to make this modification. I think the 82 used BS32 constant velocity carbs and these carbs are sensitive to airbox changes and will run really badly unless you rejet. You will also have other considerations; like what to do with the emissions equipment since the pods don't accomodate it. Not saying not to do this, only that you have a number of considerations.
- tjettim
- Thank you received: 2
24 Sep 2007 09:31 #172545
by tjettim
Replied by tjettim on topic Help me fix me bike
May I suggest getting the bike running right stock.
Do not start changing things on a bad running stock
bike and expect it to run better.Take the petcock
apart and look for contamination and worn parts.
The rubber fuel director usualy goes first.
- 76 LTD
- Thank you received: 1
26 Sep 2007 16:20 #173039
by 76 LTD
Replied by 76 LTD on topic Help me fix me bike
If it has a vacuum petcock trash it throw it in the lake drop it down a well just get rid of it.spend the extra $$$ to convert to the older style.
- BSKZ650
- Thank you received: 14
27 Sep 2007 04:56 #173139
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Help me fix me bike
if the petcock is bad and the carbs are leaking fuel, then its a good possibility that there is a lot of rust in the tank.
drain all the fuel and clean the tank prior to installing a new petcock, make sure you have a good fuel filter in line.
I would agree, get the bike running good first, then start to make changes
- JMKZHI
- Thank you received: 48
27 Sep 2007 07:25 - 03 Dec 2008 07:57 #173159
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 03 Dec 2008 07:57 by JMKZHI.
