carb synch issue
- rdgrnr
carb synch issue
15 Sep 2007 16:06
Hi,
I am trying to manually synch the carbs from my 650 off of the bike. The manual says to use a .5 to 1 mm (.02 to .04 in )wire. The closest thing I could find is a 3/64" drill bit, which is close to about .035" on a feeler guage. The problem I am having is that I can't close the slide far enough to touch to drill bit. It feels like the needle is bottoming out in the jet before the slide goes down far enough to use the bit. Am I doing this wrong?
Thanks
Thanks
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- elwood
Re: carb synch issue
15 Sep 2007 17:01
Hello, maybe check your idle adjusting screw to see if it is keeping your throttle open a little. Just a thought.
- prhladio
15 Sep 2007 17:47
I followed the directions for the carb bench sync from the filebase on this site and it said to use 1/4" drill bits. That's what I used and it worked great.
1980 KZ650E1 LTD - WG coil mod, converted to electronic ignition, loudhvx home made ignitor using HEI ignition parts
- rdgrnr
15 Sep 2007 17:55
1/4" would make more sense. Where is the filebase you are talking about? I looked in the filebase in the 77 KZ650B section, and I couldn't find anything about carb adjustments...maybe I'm looking in the wrong place?
Post edited by: rdgrnr, at: 2007/09/15 21:02
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- JMKZHI
Last edit: 03 Dec 2008 09:34 by JMKZHI.
- rdgrnr
15 Sep 2007 19:33
OK,
I understand using the bit for all to be the same. What side do I gap from? The intake side, or the engine side?
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- OKC_Kent
15 Sep 2007 21:00
I gapped from the engine side.
Cashion, OK
78 KZ650 B2 85,000+ miles
- rdgrnr
16 Sep 2007 10:49
Carbs are synchronized..I adjusted the gap to about .75mm and it runs great. The drill bit trick worked great when they all slid out at the same time. I thought about maybe having them manometered, but the bike runs so good, why mess with it. Thanks for everyone's input on this.
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- JMKZHI
Last edit: 03 Dec 2008 09:36 by JMKZHI.
