reading plugs and carb jets
- krazyjay99
14 Sep 2007 14:58
Im rejetting my carbs after new pods and 4 in 1 pipe. I think im almost set any feedback would be nice. I have a 78 kz1000ltd with 26s im on 117.5 mains 20 pilots and 5cn7 on the third slot and screw at 1 1/2 turns idles good pulls hard all the way through and here is my plug. The only issue i have is i think my needle may be just a touch lean, on a steady cruise at about 4000 rpm it doesnt hesitate but feals like it is ready to just on the edge and once in a while it will spiff back through one of the carbs i think this means im just a hare lean in the middle. i tryed adjusting the screw for it but that didnt do it. Can anyone confirm or denie these assumptions?
BTW
I gotta say thanks to wiredgeoge for all his help and input hes been real informative.
____________________________________________________
buy a man a meal feed him for a day, teach him to hunt he will eat for a lifetime.
BTW
- Bluemeanie
Re: reading plugs and carb jets
14 Sep 2007 15:30
Does look lean to me, shouldn't be more of a tan color? Was this a "plug chop" or did you just remove plug?
- KZErider
14 Sep 2007 16:44
Don't mean to horn in here, but I don't get " Was this a 'plug chop' or did you just remove the plug?" I searched "plug chop" and came up 0.
81 KZ750E2(project), 81 KZ750E2(parts donor), 87 BMW K 75C - got it runnin, didn't care for it, holding for family member, 79 CB650(project) Nomad 1700, VStar 950
- krazyjay99
14 Sep 2007 17:05
this was just a pull from a 2 mile test run on new plugs. Im just trying to determine my current setup to finish fine tuneing the carb setup.Sorry for the confusion.
- Biquetoast
- King Jeremy The Wicked
15 Sep 2007 10:58
krazyjay99 wrote:
KZErider wrote:
You really need to see the plugs color from an idle-only for the pilot section of the carbs, and the "chop" method (if you need to) for the main section of the carbs. Just riding around and looking at the plugs later *might* give you a misleading result, since it doesn't target a specific section of the carbs (though most likely the color would reflect the pilot section since the bike is idling when you turn it off)... Thuth be told, I've never needed to do a plug chop...
Ya know, I think 2 miles isn't enough to really tell. It does look mighty lean though, but you have to make sure the engine is up to temp, bla bla bla... You're looking for a nice tan. You'll know when you see it...this was just a pull from a 2 mile test run on new plugs...
KZErider wrote:
A "chop" is when you ride at a speed that is fast enough or high enough RPMs so you are using the main section of the carbs, then you "chop" off the engine by instantly pulling in the clutch, killing the kill switch, and rolling to a stop on the side of the road to check your plugs....I don't get " Was this a 'plug chop' or did you just remove the plug?"...
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
kz750twins.com
- SLEEPER650
15 Sep 2007 14:22
READING YOUR POST AND LOOKING AT YOUR PLUG I WOULD SO YOU NEED TO STEP UP ON YOUR MAIN AND PILOT JETS!
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
82 kz1100
- SLEEPER650
15 Sep 2007 14:26
78 650sr my baby
82 kz1100
82 kz1100
