Oil In Air Box
  • WMKZ900
  • WMKZ900's Avatar Topic Author
Oil In Air Box
11 Sep 2007 19:18
#170073
New Member, owner of 76 Kz900.
I have many questions. One being my stock air box collects a considerable amount of motor oil. I am assuming it is coming up through the breather. I just cleaned the k&n air filter and noticed about 5 to 6 oz of oil in the air box. What is the problem causing this?
Have and Running
66 Honda S90
71 Honda CB350
71 Kawasaki H1 500
73 Kawasaki H2 750
76 Kawasaki KZ900
06 Kawasaki Concours
Had
65 Honda S65
68 Honda CL 175
71 Honda CB 450
72 Kawasaki H2 750
74 Kawasaki H2 750
  • KZQ
  • KZQ's Avatar
  • Away
  • Administrator
Re: Oil In Air Box
11 Sep 2007 19:51
#170083
Sounds like a bunch of blowby. have you checked the compression?
kzcsi
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Re: Oil In Air Box
12 Sep 2007 14:22
#170193
There are two drain holes at bottom of air box. Perhaps clogged? :unsure:
  • WMKZ900
Re: Oil In Air Box
12 Sep 2007 17:33
#170221
I failed to note that the oil accumulation is over approximately four years. This might help to show the problem in a better light.
I will check the drain holes and see if they are clogged.
Have and Running
66 Honda S90
71 Honda CB350
71 Kawasaki H1 500
73 Kawasaki H2 750
76 Kawasaki KZ900
Had
65 Honda S65
68 Honda CL 175
71 Honda CB 450
72 Kawasaki H2 750
74 Kawasaki H2 750
Re: Oil In Air Box
12 Sep 2007 18:54
#170246
I'd clean it out really well and check it after a long ride to see if it's starting to collect again. Also, when's the last time you changed the oil? Ed
  • WMKZ900
Re: Oil In Air Box
13 Sep 2007 05:22
#170318
I just canged the oil and cleaned the air filter this past weekend. I will keep an eye on the air box to see if any oil accumulates.
Have and Running
66 Honda S90
71 Honda CB350
71 Kawasaki H1 500
73 Kawasaki H2 750
76 Kawasaki KZ900
Had
65 Honda S65
68 Honda CL 175
71 Honda CB 450
72 Kawasaki H2 750
74 Kawasaki H2 750
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Oil In Air Box
13 Sep 2007 05:47
#170322
check the compresion. if it is week the crankcase preasurizes and causes exessiveblow by wich ends up in the breather.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
