'79 KZ650 carb question
  • seanof30306
  • seanof30306's Avatar Topic Author
05 Sep 2007 22:09
#168877
OK, as I understand it, they changed the carbs on KZ650s in '79; adding accelerator pumps.
Were the carbs on '80 and '81 models the same?
Was it in '82 that they went to the smoothbores?
"That @#$%!!! KZ650"
79 KZ650 B3
Dual front disc brakes
Z1R 18" front wheel
Pumper carbs w/pods
MAC 4-1 w/ drilled-out baffle
Dyna S ignition w/ Dyna Green coils
WG coil mod
'81 CSR charging system
17/41 gearing
  • wiredgeorge
  • wiredgeorge's Avatar
Re: '79 KZ650 carb question
06 Sep 2007 06:23
#168917
The 77-78 models had VM24 with no pump... many varieties. In 79, a pump was added and there were still more varieties based on model and engine number. The pump 24s were used in 80/81 as well. In 82, BS32 constant velocity carbs were used. Smoothbore is a term for an aftermarket Mikuni mechanical slide carburetor with a "smoothbore" block installed and this carburetor was never installed as OEM on any bike. The the parts diagrams on Kawasaki.com for the various configurations of assemblies.
Post edited by: wiredgeorge, at: 2007/09/06 09:23
  • tjettim
  • tjettim's Avatar
07 Sep 2007 07:52
#169173
My cousin had a SR650 that came with
22mm carbs.We put the 26s off my 77
KZ1000 on it with a pipe and K&Ns,it
ran great after that.A simple swap.
The 26s are easy to jet and adjust.
  • wiredgeorge
08 Sep 2007 10:47
#169383
Not all 26s will fit a KZ650. Some 26s have interference between the mounting bracket and KZ650 valve cover. If you use a set of 26s (without pumps), I would stay with 1978 or 1978 1/2 type to avoid fitment problems. I think the fitment issue would occur with the 76 and 77 type VM26; definitely the 76.
