Proper jets?
  • AeroSS_87
  • AeroSS_87's Avatar Topic Author
Proper jets?
02 Sep 2007 20:34
#168119
Hey guys. I'm just wanting to know what size jets and what slot to put the clips in on the needles for my KZ550. It's stock engine, kerker pipe, and will have pods on them. Thanks!
  • loudhvx
  • loudhvx's Avatar
Re: Proper jets?
03 Sep 2007 08:03
#168200
What bike model exactly?
I'm assuming it's the 82 KZ550 C3 (LTD) from your photo. Those use Teikei TK-22 carbs.
The stock main is a 92. The stock USA needles (4D92) are not adjustable. If you have the adjustable version of the needles (4D93), which come in some of the rebuild kits out there, you want it on the second groove from the top, which matches stock, or the third groove from the top, which makes it richer than stock. Don't mess with shims on the needles, it can cause them to bind in the carb.
With Kerker alone, you can sometimes just use the stock settings in the carbs, but 94 mains would probably help.
With Kerker and pods you'll want 96 or 98 mains and maybe use the third groove on the needle if you have that option.
If you set the airscrews at idle, and the proper mixture results in a 1/2 turn out or less, you may want to consider enlarging the stock 32 pilot jet to 37, but only if you are not satisfied with the idle (and slightly off-idle) performance.
You can use small Keihin jets, but not Mikuni.
Here's another mod for those carbs you may want to consider if you're having cold-idle issues.
www.geocities.com/loudgpz/GPZchokeScrewMod.html
If it's not a C3 LTD then this info may not apply.
Post edited by: loudhvx, at: 2007/09/03 11:11
  • AeroSS_87
Re: Proper jets?
03 Sep 2007 10:12
#168232
wow thanks alot for the detailed response!
