Another 29mm smoothbore setting ?
- GregZ
28 Aug 2007 17:52
Hello First off I'm new here. I rode harleys for 17 years,sold my last one and bought a 75 Zed off fleybay last month for $1650 buy it now. I am the third owner, 20k miles. Bikes runs good. Bike is stock. I put on a V&H 4 into one and plan on installing a set of 29 mm smoothbores.Heres what I have.
29mm smoothbore -stamped 29A7
1.5 throttle valve
needle on third clip
120 mains
25 pilot
emgo oval pods
My question is should I change the pilots to a 20 thanks
Post edited by: GregZ, at: 2007/08/28 21:16
1.5 throttle valve
120 mains
25 pilot
emgo oval pods
- reborn650
Re: Another 29mm smoothbore setting ?
28 Aug 2007 18:11
Welcome Greg - Former HD owners are always embraced here at Kzr...as long as you have sworn off the twins-for good.
Our resident carb expert is wiredgeorge. He checks in here pretty much every day and has set up quite a successful business dealing exclusively in carbs for old Japanese bikes.
His website is wgcarbs.com
If you would like to also see another reputable contributor to our little community then get to know Jeff @ Z1 Enterprises.
As a matter of fact, Jeff has a page that deals with recommended setting for the carbs for your old 900.
Check it out here
www.z1enterprises.com/reference/z1-carb-guide.aspx
Good luck with the new-old bike and keep the shiny side up.
P.S. When you ride with your old Harley friends, bring a little old oily rag to smudge across your 900's engine, just to make it look like your new ride is leaking some oil...like theirs:)
Check it out here
-1998 Jeep TJ Wrangler 4.0...
